window water - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 7 (permalink) Old Jun 11th, 13, 08:09 AM Thread Starter
Big daddy
window water
Anybody know how to remove water vapor from double insulation window?without replaceing.
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 7 (permalink) Old Jun 11th, 13, 08:56 AM
DjD
DjD's Avatar
Re: window water
If you are talking about double pane windows, if there is moisture between the 2 pieces of glass the seal is gone and the windows need to be replaced according to the folks that sold me the windows in my house. Most double pane windows have a fairly long warrantee to cover the seal between the glass...
...Dennis
DjD is offline
post #3 of 7 (permalink) Old Jun 11th, 13, 09:18 AM
Guess
HwyStarJoe's Avatar
Re: window water
That's what I was always lead to believe also... once the seal is compromised, any gas that was between the panes is gone.
HwyStarJoe is offline
post #4 of 7 (permalink) Old Jun 11th, 13, 10:02 AM
Vintage 68's Avatar
Wink Re: window water
Check to see if you have a 'Glass Doctor' franchise in your area.
I've used them several times to repair 'fogged' dual-pane windows in several homes.
They will come out and access your window and see if they can repair it in place or if it would have to removed/replaced to be done right.
Pricing was well under getting a replacement unit.
Found their locator link - http://www.glassdoctor.com/About-Us/AllLocations.html
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 7 (permalink) Old Jun 11th, 13, 10:52 AM
DjD
DjD's Avatar
Re: window water
I think even Glass Dr replaces the glass unit within the window frame, I don't think they have a way to dry out the air pocket and re-seal and reuse the original glass...
...Dennis
DjD is offline
post #6 of 7 (permalink) Old Jun 11th, 13, 11:01 AM
Vintage 68's Avatar
At the mountain house - they drilled small holes in the corners, sprayed cleaning/drying agents through the interstitial space, pulled a vacuum (not sure of value) on it and then sealed up the holes ...
Not one unit, of 4, was 'replaced'
Guy came out of Reno to do the work.
1968 Convertible
Some trucks
post #7 of 7 (permalink) Old Jun 11th, 13, 02:37 PM Thread Starter
Big daddy
Re: window water
Thanks guys,no glass doc on okc.Will jus replace.
carhodge is offline
