1982 cutlass - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 5 (permalink) Old Jun 12th, 13, 05:37 AM Thread Starter
corey
1982 cutlass
Hey Guys just havin a bit of trouble here , I have a 82 cutlass with a abc 350 in it , Now i just put in the ford taurus elec fan. I have the stock alt in the car with just lights, windows and a street fire dizzy running off it, with out the fan i am getting 14 volts with the fan i am getting 12 . Everyone I talk to says the alt can handle it , I have a 80 amp relay wired in and I got the basic wiring diagram from the site so I no its all wired up correctly , any suggestions would be great the attached picture is how mine is wired
steps350 is offline
post #2 of 5 (permalink) Old Jun 12th, 13, 09:21 PM Thread Starter
corey
Re: 1982 cutlass
bump
steps350 is offline
post #3 of 5 (permalink) Old Jun 12th, 13, 10:24 PM
Vintage 68's Avatar
Question Re: 1982 cutlass
The wiring is fine
But you didnt state whether this is a single or dual speed Taurus unit AND is it a new one, or a used fan unit on it's last leg ...
A good fan system will draw @60+ amps 'inrush' and then settle at @35~40 amps run in low and @20 more for the high speed if a dual speed unit.
Old units can be real amp-hogs
Try checking the fan motor temp while running - if it's getting way hot to the touch there's a good chance it's bad and the source of your issue.
It never hurts to switch to a 100~120 amp unit if adding an electric fan to be sure your system can provide enough power
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 5 (permalink) Old Jun 13th, 13, 03:23 AM
Re: 1982 cutlass
A troubleshooting tool for current is a Harbor Freight Ammeter, $9.
With fans on, engine running, alt case should be hot to the touch.
Again temp gun, HF, $30.
post #5 of 5 (permalink) Old Jun 13th, 13, 03:19 PM Thread Starter
corey
Re: 1982 cutlass
hey sorry yea its a duel speed fan and I just have it on the high speed , the fan didnt seem to get overly hot
steps350 is offline
