1990 Honda Accord Charging Problem - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 6 (permalink) Old Aug 23rd, 13, 08:36 AM Thread Starter
My GF pulled into the driveway the other evening after a 20 mile drive with very dim headlights, the stereo going wacky and the dash battery light on. After she shut it off, it would barely crank - depleted battery, 11.7 volts measured at the posts.
I was too tired to do anything but put a charger on it and left it overnight @ 2 amps. This morning it fired right up, no batt light, runs perfectly. Belt is tight, and a steady 14.6 @ the batt posts with the engine running.
I suspect a failing alternator.
All opinions welcomed and appreciated!!
Thanks.
BPOS is offline
post #2 of 6 (permalink) Old Aug 23rd, 13, 09:28 AM
Re: 1990 Honda Accord Charging Problem
Either the alt as you suggest or R&R the alternator fuse as corrosion may have formed.
Throw a jumpbox into the trunk and show her how-to-use.
post #3 of 6 (permalink) Old Aug 23rd, 13, 09:46 AM
Bryon
bcm66's Avatar
Al, I am not sure. Could be alternator or battery. I would suspect alternator first.
But checking for corrosion on all connections is also a good idea. That could cause the symptoms too.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #4 of 6 (permalink) Old Aug 23rd, 13, 09:55 AM
Andrew
Andrew69's Avatar
Symptoms sound like the alternator. I put a new alternator on my wife's '99 Accord last year. It was acting similar to yours.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #5 of 6 (permalink) Old Aug 24th, 13, 08:06 PM Thread Starter
Thanks for the help guys. Replaced the alternator and the belt, all seems good. Makes one appreciate working on an old Chevy.
BPOS is offline
post #6 of 6 (permalink) Old Aug 30th, 13, 09:19 AM
Bryon
bcm66's Avatar
Good deal. I am glad it was a fairly simple fix.
CRG -
bcm66 is offline
