200 F-150 4.2 oil filter housing gasket - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 12 (permalink) Old Nov 12th, 13, 05:49 PM Thread Starter
keith
X-77 keith's Avatar
My brother owns this truck , not me, honestly. The truck has developed a coolant leak near the oil filter housing. I know the housing has a coolant passage way so I think that the mounting gasket is blown. I have replaced this gasket on a few V-8 trucks with no problem. The problem I have with this truck is no one sells the gasket. Ford says you have to replace the timing chain cover to get the gasket for $379.00 bucks. I tried to just get the timing chain gaskets with no luck as well. My question is does any one know if I really need to replace the cover, or does any one sell the gasket without the cover. Any help would be great, this Ford on my lift is reducing my property value.
X-77 keith
X-77 keith is offline
post #2 of 12 (permalink) Old Nov 13th, 13, 03:11 AM
Kevin
SixtyAte's Avatar
Re: 200 F-150 4.2 oil filter housing gasket
Keith,
Read this forum postings. They also list a New Gasket Kit that is very cheap from Ford.
From that forum:
The modified gasket kit is Part# XU2Z6020AA. It came with 4 studs -- 3 brass and one steel(?), 3 nuts, the water-pump gasket and timing cover gasket. It also came with a several page instruction booklet which is actually pretty good.
https://www.google.com/#q=ford+Part%23+XU2Z6020AA
http://www.ford-trucks.com/forums/41...over-leak.html
Kev
SixtyAte is offline
post #3 of 12 (permalink) Old Nov 13th, 13, 04:05 PM Thread Starter
keith
X-77 keith's Avatar
Thanks man that is what I was looking for.
X-77 keith
post #4 of 12 (permalink) Old Nov 17th, 13, 05:05 PM Thread Starter
keith
X-77 keith's Avatar
Kevin, I did the cover gasket this weekend. It sucked. I replaced the water pump, and oil pump too. After she smoke cleared that leak was fixed, but a second developed. The steel nipple pressed into the intake for the heater hose rusted from the inside out and started leaking too. Had to take the upper and lower intake off to drive a new nipple in. Fords really suck, but this truck does have 253K miles on it without any maintance. Thanks for the help, now back to the 67 Camaro resto mod that I am actually getting paid to work on.
X-77 keith
post #5 of 12 (permalink) Old Nov 18th, 13, 05:02 AM
Kevin
SixtyAte's Avatar
Keith...
Bet you are glad that it over with I have a 2005 F150 Fx4 that has the 5.4 Triton 3 valve engine. It now has 97,000 miles and I hope to get to the same amount of miles before any tear-down !
Kev
SixtyAte is offline
post #6 of 12 (permalink) Old Nov 18th, 13, 03:34 PM Thread Starter
keith
X-77 keith's Avatar
Yes I am glad it is done. I cringed every time my phone rang thinking it was broken again. No call on the truck yet. I think yours is the type that they say to take the cab off to remove and replace the engine isn't it?
X-77 keith
post #7 of 12 (permalink) Old Nov 19th, 13, 04:41 AM
Kevin
SixtyAte's Avatar
Yep...disposable engine I changed the plugs at 50,000 miles myself and it wasn't fun. With the problem of the plugs breaking off in the head , it makes that job a scary at best. Now its time to change them again, even though the factory states every 100,000 miles to change the plugs. The 50,000 interval will give the best chance at not having a plug break off. I am about ready to order the Matco BPR65 Spark Plug removal tool. Going to replace the plugs with the new one piece Champion # 7989 plugs !
Kev
SixtyAte is offline
post #8 of 12 (permalink) Old Nov 19th, 13, 10:59 AM
T.C.
I have a 2000 5.4 Supercrew. When I had to do the Plugs, I let a Dealership do in case they broke the Plugs ( they didn't).
I know that the 5.4 Intake is a plastic piece of junk - I just replaced that with a Dorman Aftermarket piece that really not much better than the Factory, although their Gasket design was better & it seemed like the Runners were a good design. The mileage has only gotten minimally better.
The Front Sway Bar Links are Garbage, but easy to replace.
Other than that the Truck is pretty good. I'm at 130,000 Miles. I will say this - Ford Dealerships give away their Oil Changes. One Dealership (they since stopped) was doing $9.99 Oil Changes. Another does the Premium Oil Change - ( Semi-Synthetic), Tire Rotation, Check & Fill all other fluids for $29.99. They have to use MotorCraft Oil & Filters. I can't do it myself that cheap!
T.C.
BMR Suspension is offline
post #9 of 12 (permalink) Old Nov 19th, 13, 11:38 AM
T.C.
Sorry Double Post!
T.C
post #10 of 12 (permalink) Old Nov 19th, 13, 04:21 PM Thread Starter
keith
X-77 keith's Avatar
I have used the Dorman intakes too. The gasket is better. The few that I put on Explorers with V8 engines had a alternator relocate bracket. The bracket that came on the truck would not fit, nor would the Dorman bracket. Between the two I could fab up a bracket that fits.
X-77 keith
post #11 of 12 (permalink) Old Nov 20th, 13, 03:13 AM
Kevin
SixtyAte's Avatar
T.C.
The plug problem started with the 2004 model Triton V8's and were corrected in the 2009 model. The dealer will charge a flat rate of $300 to $400 however have you sign a waver that if they break a spark plug its on your dime. Some were charged upwards of $3,000 to remove the heads etc.
The tool was designed to remove the broken plug..saving time and money. I plan on starting the job the night before with spraying Penetrating oil in the plug tubes and letting it sit overnight....going at it in the morning.
Kev
SixtyAte is offline
post #12 of 12 (permalink) Old Nov 20th, 13, 04:30 PM Thread Starter
keith
X-77 keith's Avatar
The last few I did came out fine. Yes I sprayed PB Blaster on them the night before. What a dumb plug design.
X-77 keith
