Washer fluid in radiator overflow... - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 5 (permalink) Old Jan 5th, 14, 06:39 PM Thread Starter
Guess
HwyStarJoe's Avatar
Question Washer fluid in radiator overflow...
I just had a buddy call me with an issue...
He just bought a new truck (don't know the make... our call got cut off), and he had just accidentally poured a bottle of washer fluid in the overflow tank. He already drained as much as he could from the tank but has to drive 10 miles home to get a turkey baster to suck the rest out. (My idea)
Is it gonna be a problem if there's some left that gets in the coolant system?
HwyStarJoe is offline
post #2 of 5 (permalink) Old Jan 5th, 14, 08:09 PM
john
wagonman's Avatar
Re: Washer fluid in radiator overflow...
I think he will have a clean cooling system....
He should be fine...
Its always a good idea to flush the cooling system every year or three..
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #3 of 5 (permalink) Old Jan 5th, 14, 08:12 PM
I wouldn't think so as the dilution value would be small.
Fluid would only be drawn into the system at cool down.
post #4 of 5 (permalink) Old Jan 5th, 14, 08:30 PM
DjD
DjD's Avatar
I had a "quickie lube" oil change once and the tech (used loosely) got the overflow and windshield washer jugs mixed up. I found out about it about an hour later when on the road heading out of town the car was overheating do to the soapy solution expanding in the radiator.
If he knows the overflow was not cycled through the radiator (engine brought up to temp) he should be able to drain the overflow, clean it out and be good to go. If any got into the core I would recommend a complete cooling system flush! The soapy washer fluid will bubble and expand causing more pressure in the system than it's designed for and will cause the engine to over heat and radiator to puke...
...Dennis
DjD is offline
post #5 of 5 (permalink) Old Jan 6th, 14, 06:23 AM Thread Starter
Guess
HwyStarJoe's Avatar
Thanks guys.
Like I said, he'd drained all that would come out of the tank before he drove it home. He wasn't in an area where he could buy or borrow a turkey baster to suck the remainder of coolant\washer fluid out. Hopefully it'll be OK.
If nothing else... he can claim someone else did it and get a warranty cooling system flush.
