1972 chevy transfer case - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 7 (permalink) Old Jun 25th, 15, 12:55 PM Thread Starter
kevin
1972 3/4 ton chevy transfer case. it is with a 3 speed transmission. anyone know where on the unit I can find some numbers as to identify it as a NP 205 or a NP 203, or any physical features that would show one or the other.
I looked the best I could and did not find any tag
any idea of the value?
thanks
flat tire is online now
post #2 of 7 (permalink) Old Jun 25th, 15, 02:33 PM
Re: 1972 chevy transfer case
205 (gear driven) is pretty high on the wants lists....203 chain driven....not so much.
Being a 3/4 T....pretty sure it should be a 205.
Mine had a round tag with a bolt in the middle.
http://www.fourwheeler.com/features/...potters-guide/
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Jun 26th, 15, 04:05 AM
This address may help:
http://www.offroaddesign.com/catalog...ID%20Guide.htm
Doug's site helps as well.
post #4 of 7 (permalink) Old Jun 26th, 15, 04:59 AM Thread Starter
kevin
thanks fellows
post #5 of 7 (permalink) Old Jun 26th, 15, 06:20 PM
Kev
The internet has pictures. You can look at them and then at the TC to see which it is.
Chances are its a 205. Also, on a 205 in the back there's a little round cover about 2" in diameter.
67sc is offline
post #6 of 7 (permalink) Old Jun 27th, 15, 07:46 AM
Virgil
A NP 203 is a full time 4wd transfer case UNLESS it has been converted. As said above, it is chain driven where the NP 205 is gear driven. The 203 has lower gears than a 205. and the 203 is about 40 pounds heavier.
Also, the 205 is "flat faced" across the front, where the 203 has a rounded front until you get to the chain, and the 205 will have a 3 bolt cover on the back that covers one of the idler shafts.
vr1967 is offline
post #7 of 7 (permalink) Old Jun 27th, 15, 08:17 AM Thread Starter
kevin
it is confirmed. 205
thank all
