Jeep driveline bad grinding noise help - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 8 (permalink) Old Dec 15th, 15, 02:45 PM Thread Starter
Greg
pittpens24's Avatar
Hey guys looking for help with this. I have a '05 Jeep Rubicon 6 speed. It started making this grinding noise like metal to metal when your disc brakes go. Sounded to me like a bad bearing. The sound was pretty much non existent during acceleration and when the clutch was pressed to the floor. Sound was god awful during deceleration while still in gear with the clutch engaged. Push in the clutch - grinding goes away - let it out slowly and grinding comes back and get louder the more the clutch pedal is released. Last week went into the shop for a replacement trans from mopar. Was told it was a bad input shaft bearing. I was getting prices from $1500 and up to repair or $2500 for a new rebuilt right from mopar with a 3 year/100,000 mile warranty. Thought it would be beneficial to go with the new rebuilt and warranty. Needless to say just got it back today $3200 in the hole and sound is still there - just ALOT quieter. Think I got a bad trans??? Any thoughts? They told me to drive it until they talk to mopar warranty dept.
thanks guys
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #2 of 8 (permalink) Old Dec 15th, 15, 02:49 PM
mike
Re: Jeep driveline bad grinding noise help
Any way to pinpoint where exactly the noise comes from. Maybe someone walk or drive next to you and listen. It could just be another bad tranny. T
bigblockragtop is offline
post #3 of 8 (permalink) Old Dec 15th, 15, 04:10 PM Thread Starter
Greg
pittpens24's Avatar
Poor mans stethoscope(long handled screwdriver) to the trans case and it seems to be inside. May be transferring through the transfer case??? I am at a loss
Moser 9" with 4:11
572 BB - CM Engines
post #4 of 8 (permalink) Old Dec 15th, 15, 06:03 PM
mike
I think since it got A LOT quieter with the new trans but still there, I would think the new trans has a problem also. If they think the new trans is fine then tell them to extend the warranty because you don't feel it is fine.
post #5 of 8 (permalink) Old Dec 17th, 15, 03:10 AM
George
Gbauer's Avatar
Which transfer case?
I had a 249 transfer case that grenaded on me. Sounded like that before it hallened. With the TC bolted to the transmission it could sound like it's coming from the trans.
I don't know if it can be done with the new jeeps but a 249HD transfer case isn't very expensive and is quite an upgrade.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 8 (permalink) Old Dec 20th, 15, 06:38 AM Thread Starter
Greg
pittpens24's Avatar
Ok so here is the conclusion. It apparently was the CV joint in my driveshaft - chalk up another $300 to the equation. This is what has my head spinning tho. I told them to check the drive shafts 1st thing. They said they were fine and it was the trans. So did I get a new trans for nothing if the was the same noise as before the new trans just minimal or just a coincidence???? Maybe they greased the joints in the bad shaft when they replaced my trans and that made the sound minimal? Worst part is - they took my old trans when they delivered the new for the core - if I just got ripped off, I will never know.
Moser 9" with 4:11
572 BB - CM Engines
post #7 of 8 (permalink) Old Dec 20th, 15, 03:38 PM
mike
Even if they did not diagnose properly, if you plan on keeping the Jeep at least now you have a new tranny with a warranty(and some more experience).
post #8 of 8 (permalink) Old Dec 21st, 15, 07:19 AM Thread Starter
Greg
pittpens24's Avatar
Jeep is definitely a keeper! Thing is paid off and this the is 1st investment that I had to do to it since new - other than all the mods I did and normal wear and tear items. Ready to go another 100,000 now
Moser 9" with 4:11
572 BB - CM Engines
