Snow blower help - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 16 (permalink) Old Jan 23rd, 16, 03:34 PM Thread Starter
Greg
pittpens24's Avatar
Snow blower help
This is my luck. Started and gassed it up last night in preparation. Got all of 10' and looked like it was leaking gas. Tore it apart thinking a mouse got to the fuel line. All looked good. Thought maybe the float was sticking - good there too. Fired it up appeared to be good then started leaking bad from the Valve cover breather - I knew I was in trouble. Took off the breather and it hit me that maybe a seal or gasket went???? I checked the oil and the dipstick about blew out of my hand - the crankcase was full of gas and oil. Any ideas what to check? It is an 8hp Honda. Any help would be great - we are at 22" here
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #2 of 16 (permalink) Old Jan 23rd, 16, 04:34 PM
jerry
JERRYS 69 Z's Avatar
Re: Snow blower help
Check the needle and seat. If the needle doesn't seat it will flood the carb and
Gas will leak into the crankcase. Also, be sure to drain crankcase oil and install
New oil Filter if it has one. I would also put a shut off valve in gas line. Shut valve
Off after every use. Hope this helps.
JERRYS 69 Z is offline
post #3 of 16 (permalink) Old Jan 23rd, 16, 04:40 PM
X 2
68 Camaro~LSx ~all motor
post #4 of 16 (permalink) Old Jan 23rd, 16, 04:41 PM Thread Starter
Greg
pittpens24's Avatar
Thanks Jerry - will try that in the am. Has a shut out valve.
Moser 9" with 4:11
572 BB - CM Engines
post #5 of 16 (permalink) Old Jan 23rd, 16, 04:59 PM
My brother lives in NE Jersey and sent me a pic of a tape measure jammed into the snow. As of 7:30pm he was up to 25 inches of snow. I told him to move south and forget the snow blower. LOL.
BRICO69 is offline
post #6 of 16 (permalink) Old Jan 23rd, 16, 05:17 PM
George
Gbauer's Avatar
Just 25?
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #7 of 16 (permalink) Old Jan 24th, 16, 03:57 AM Thread Starter
Greg
pittpens24's Avatar
I am in Blairstown and the final count is 22". Thanks guys for the help. Not sure if and what will be open today to get oil to try and get the blower goin being that this is a hick town lol.
Moser 9" with 4:11
572 BB - CM Engines
post #8 of 16 (permalink) Old Jan 24th, 16, 04:04 AM
With the suggestions of others, I'll add carb may need cleaning as needle & seat are two separate entities working against each other along with sediment in the bowl.
My suggestion is add Sta-Bil, fuel stabilizer, to the gas can.
I use it year around, 2 oz per 5 gals, I think - follow instructions, but you can never have too much.
I have used it for the last 10 years and have not had a problem with any engine.
A good 10W30 oil will do good for the Honda engine - whatever is on the oil cap.
post #9 of 16 (permalink) Old Jan 24th, 16, 04:11 AM
kevin
flat tire is offline
post #10 of 16 (permalink) Old Jan 24th, 16, 04:13 AM Thread Starter
Greg
pittpens24's Avatar
Thanks - ill add that to the list - that is if my town will even be open today.....
Moser 9" with 4:11
572 BB - CM Engines
post #11 of 16 (permalink) Old Jan 24th, 16, 08:24 AM
I have yet to find '710' at Home Depot or Lowes - may be a special oil...
At the last run of the season, you may want to shut off the fuel and let the engine run carb dry.
There might be a drain valve on the bowl for emptying - spring loaded petcock to push in?
post #12 of 16 (permalink) Old Jan 24th, 16, 09:38 AM
Jimmie-Retired
^^^ What Everett said. I never leave gas in anything at the end of the season. Weed whacker, chain saw, snow blower, lawn mower, whatever. I think that ethanol blend gas plays havoc with small engine carburetors. Big ones too. My adult sons haven't figured that out yet and have dirt bikes, riding mowers, and go karts that won't run.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
post #13 of 16 (permalink) Old Jan 24th, 16, 10:13 AM Thread Starter
Greg
pittpens24's Avatar
Thanks alot guys. I checked the float yesterday and it appeared to be fine. Took the whole carb apart and gave it a good cleaning. Changed the oil and voila - good as new. I had siphoned out all the gas at the end of last season but never drained the carb - lesson learned. I also bought a bottle of Seafoam additive to get me through the winter season. Thanks again to all who posted.
Moser 9" with 4:11
572 BB - CM Engines
post #14 of 16 (permalink) Old Jan 24th, 16, 10:44 AM
Steiner
We're lucky enough to have ethanol-free 87 at several stations. Even so I put the regular red Sta-Bil in the cans every time I fill them up, even during season when I go through it at a decent pace since it may get shared in stuff where it doesn't get burned as fast. Sometimes I get ethanol gas in the cans and in that case use the blue marine 360 Sta-Bil.
http://www.goldeagle.com/product/sta-bil-360-marine
'69 Camaro
500hp/538lbft
Steiner is offline
post #15 of 16 (permalink) Old Jan 24th, 16, 11:07 AM
69-Pace's Avatar
Greg glad to see you are back in the fight.
I had a similar problem last year in our winter from hell where the spring loaded peacock rubber seal had dry rotted so it was leaking more fuel then burning and of course it was like midnight, over a foot of snow on the walks and driveway and 20 degrees in the garage.
I managed to Frankenstein a seal from some small O rings I had kicking around the bench and that got me through that night. The next morning I bought a replacement carb and extra bowl one without the peacock on-line over night shipping. Once bitten, twice smart, twice as poor.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
