Bolt Pattern Mismatch ... - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
 1Likes
  • 1 Post By dhutton
post #1 of 9 (permalink) Old Aug 22nd, 17, 07:20 PM Thread Starter
Larry
One of my projects, 54 Ford F100 has been put in a mismatch situation on the wheel bolt patterns.
The front end was subframed with a 78 Pontiac Trans AM front clip and the rear axle was swapped to a Lincoln 12" disc brake axle.
The good part is I end up with a great handling truck with four wheel power disc brakes.
The bad part is I need to change either the front or the rear to get a match on the lug pattern all around the truck.
Looking for some input regarding which is the easiest or best to change. I could just purchase new axles for someplace like Currie, I'm guessing they can put any bolt pattern imaginable on new axles.
How about the front rotors? Is there anyplace selling custom bolt patterns on these GM rotors?
I would imagine there would be some serious liability concerns for any machine shop willing to re-drill rotors to a new bolt pattern?
I'd be willing to get any advice out there on this problem. Two patterns on one truck isn't going to cut it.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #2 of 9 (permalink) Old Aug 23rd, 17, 05:57 AM
Re: Bolt Pattern Mismatch ...
I would consult with your machinist to see which disc rotor has the most meat on it to redrill one end or the other.
Big Dave
Larger Dave is offline
post #3 of 9 (permalink) Old Aug 23rd, 17, 09:57 AM
Curious why you want to make them the same. Could probably be done most easily using adaptor wheel spacers.
ZZ_430 likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 9 (permalink) Old Aug 23rd, 17, 03:42 PM Thread Starter
Larry
Big Dave
I'll have to check in with him and see what his pulse is on this type thing.
As I noted in the OP, I can imagine there are some liability aspects to a machinist doing this.
post #5 of 9 (permalink) Old Aug 23rd, 17, 03:48 PM Thread Starter
Larry
Well, I'd like to do this so I don't have two different bolt patterns on the truck. I'd like to be able to do things like rotate tires, have a single matching spare in the rotation etc.
I am not too keen on the adapter plates. Maybe on the rear of a vehicle, but I could not do it on the rear of this truck, just not enough fender clearance to push tire outward.
Putting adapters on the front is where I'm really not too keen on the idea.
Also my tracking width is only .5" off right now with the front a tad wider. I'd like to not push that measurement further off.
post #6 of 9 (permalink) Old Aug 23rd, 17, 03:53 PM
Robert
The easiest would probably be to just get new rear axles. You can always just carry 2 spare tires!!!
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is online now
post #7 of 9 (permalink) Old Aug 23rd, 17, 03:53 PM Thread Starter
Larry
I suppose there are uni-lug wheels out there as well that could possibly work around this.
post #8 of 9 (permalink) Old Aug 23rd, 17, 06:03 PM
scblucam's Avatar
You could just pull the axles and have the other bolt pattern drilled in between what is there. Or if you want new axles I think I have seen them where you can buy them double drilled.
68 302 M20 - 85 IROC Z
scblucam is offline
post #9 of 9 (permalink) Old Aug 23rd, 17, 06:33 PM Thread Starter
Larry
Doing the rear might boil down to (assuming a machine shop will drill it) the cost to redrill compared to the cost of new axles.
Then there are these, just stumbled onto this:
1973-77 GM Midsize 11 Inch Brake Rotor, 5 on 5 Inch
