Variable brake "pedal" in my pickup - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 1 (permalink) Old Oct 21st, 17, 08:44 AM Thread Starter
yesterday i developed varible pedal in my pickups brakes. The issue generated no warnings, no noise, no "feel", no missing fluid in the tank, no obvious leaks at the wheel cylinders. The pedal did not go to the floor and would pump up. The pedal did not pulse. The cause was the front left 4wd spindle bearing assembly checking out with no drama. Never ran into this before. Usually there is much more fanfare.
3d cad is offline
