gas mix question - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 8 (permalink) Old Jun 25th, 18, 08:45 AM Thread Starter
gas mix question
Some weekends I run with a another old guy who races. It happens to be a Ford FE that's in a stang that's completely old school. Parked in 81 when the twins were born, woke up 3/4 years ago. runs high 10's. Normally runs VP Vintage Leaded. For some reason he dumped some VP C-12 in it after the first round. Till the day was over it was running a half second slower and we were scratching our heads until we noticed the fuel can. The bottom line question here is if we should pull the heads for a look. After a look on line at the chemistry I can see this was too far a jump, minimum of 12 max of 16 depending on which scale you use. I don't have any kind of experience with what a rash move in octane into the slow burning ranges does to a NA motor that's having the snot wrung out of it.
thoughts?
3d cad is offline
post #2 of 8 (permalink) Old Jun 25th, 18, 09:04 AM
Vega$69's Avatar
Re: gas mix question
Put the other fuel in it and see if it runs faster again
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 8 (permalink) Old Jun 25th, 18, 09:07 AM
Darin
ilikeike's Avatar
I know if I play with higher octane fuel, I have to adjust my timing to burn it properly.
I'd go back to the fuel his tune is set up for,unless he's going to get on a dyno or use up his track time playing with his tune.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 8 (permalink) Old Jun 25th, 18, 09:29 AM Thread Starter
I was worried about damage. That jump is so great that with the slow burn we may have been blowing gas out the pipe and running lean. Getting that side oiler apart in the car is a task for younger guys.
3d cad is offline
post #5 of 8 (permalink) Old Jun 25th, 18, 10:49 AM
mike
I doubt there's damage usually detonation causes damage(if he got lower octane).
bigblockragtop is offline
post #6 of 8 (permalink) Old Jun 25th, 18, 11:20 AM
kevin
I asked a ? about Av gas compared to 110 and got no answer here. another forum posted several links. the one link stated there is no such thing as to much octane only to little
this was not from an individual, but from someone with knowledge of fuels
flat tire is online now
post #7 of 8 (permalink) Old Jun 25th, 18, 11:30 AM
Sean
Very doubtful there is any damage, I would bank on there not being any in fact (from the gas that is).
As you may know higher octane = slower burn. If you donít need it (compression, timing) it only hurts performance. It may or may not be noticeable, but that jump clearly made a difference. He may have been able to pick it back up with more timing, but it depends on what the motor wants.
You can however kill a motor with detonation using too little octane. Too much I imagine can hurt eventually but it would have to be an unusual situation Iíd think.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #8 of 8 (permalink) Old Jun 25th, 18, 12:06 PM
DjD
DjD's Avatar
Higher octane burns slower and does not equate to more power. You should use the lowest octane rating you can without causing pinging, detonation, run-on etc. Higher compression will require a higher octane rating but you still shoot for the lowest you can safely run...
...Dennis
DjD is offline
post #9 of 8 (permalink) Old Jun 25th, 18, 02:12 PM
kevin
