K&N vs. Green Filter - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 7 (permalink) Old Oct 1st, 18, 05:00 AM Thread Starter
Ed
So I have been running K&N air filter for years without even thinking about it. A couple days ago a friend recommended a new filter called Green Filter air filters. So I want everyone opinions on it. Below are the links to K&N Filters and Green Filters. Let me know your thoughts and opinions.
https://www.knfilters.com/default.aspx
https://greenfilter.com
ZEN357 is offline
post #2 of 7 (permalink) Old Oct 1st, 18, 06:20 AM
Darin
ilikeike's Avatar
Re: K&N vs. Green Filter
I've run K&N since the 80s
Blue and Black options would be nice. Not into green.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 7 (permalink) Old Oct 1st, 18, 07:02 AM
Great marketing campaign. Not enough information to determine cost/benefit.
3d cad is offline
post #4 of 7 (permalink) Old Oct 1st, 18, 10:24 AM
Greg
pittpens24's Avatar
Since the green filters screens are made of steel, won't they rust?
And the fibers breaking down - you probably have more fibers going through your motor when you take your carb off and stuff a rag in there - I think they are reaching
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #5 of 7 (permalink) Old Dec 11th, 18, 05:52 AM Thread Starter
Ed
I have heard they flow more CFM and are lest restrictive but the fit & finish rank at the lowest of other air filters.
ZEN357 is offline
post #6 of 7 (permalink) Old Dec 12th, 18, 05:08 AM Thread Starter
Ed
Ok, so I contacted the company yesterday and found out the make the filter frame out of stainless steel to prevent rusting. Also attached is a comparison chart that was posted on another forum.
ZEN357 is offline
post #7 of 7 (permalink) Old Dec 13th, 18, 09:26 PM
Sean
Not sure about “Green filters”, but if you’re shopping filters take a look at R2C, they are really well made, flow well and no oil. They are designed for dirt track use.
I’ve been using one for a few years now with good results.
Just an option.
Sean
Franklin D. Roosevelt
68rs406 is offline
