Car Wont shut off *Help* - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 4th, 07, 01:42 PM Thread Starter
Send a message via AIM to 67camaro02
So heres the story, just did some work on my motor and inside, wired some stuff in. got my car back together and started it and it starts great but now when i shut it off, it just stays on. only way i can kill it is to turn my dist. even with the keys out it stays on. is there an online guide or what?
67camaro02 is offline
post #2 of 6 (permalink) Old Feb 4th, 07, 01:50 PM
mike
Re: Car Wont shut off *Help*
could be the alternator is backfeeding the ignition...lol...i`ve done that before...1 or 3 wire alternator???if 1 wire, it wont do that i dont think as the alt only puts out voltage when "excited"...(needs to be spinning faster than idle)but if 3 wire, the field wire needs to be switched, or it makes power at idle and backfeeds the ignition
kustomwerker is offline
post #3 of 6 (permalink) Old Feb 4th, 07, 04:19 PM Thread Starter
its a 1 wire alt. i think it has to do with adding some guages on the inside of my car, what color of wire should i not have spliced into? lol
post #4 of 6 (permalink) Old Feb 4th, 07, 04:50 PM
mike
you have to be backfeeding the ignition circuit...with the key off, test the hot wire on the dist...if its hot with the key off, thats your problem...then with the test light still connected and visible, start disconnecting the things you added until you find the culprit...i`d think ammeter guage???
post #5 of 6 (permalink) Old Feb 4th, 07, 07:57 PM Thread Starter
Welp, i did find it weird thing was it was a cable connected to the battery ran all the way around the front of the radiator and down the drivers side and went straight into my ign. fuse box, used to be used for my stereo but i havent had a stereo in sometime. just disconnected it and pulled it all out and all is well know...thanks kustom!
post #6 of 6 (permalink) Old Feb 5th, 07, 03:53 AM
The wire you speak of is the power wire from the battery to feed the car. You disconnected it, this interrupted power from BAT terminal of the alt, and opened the circuit to the ign switch for ignition.
You should change over to 3-wire alt and changing harness is all that is needed.
Internal regulated alts, 72 & newer?, get sense voltage, Terminal #2, from ignition switch. So, later igniton switches have two switched IGN posts, one for HEI & the other for the alt. First gen's have a single post/terminal. Turn off sense voltage, turn off alt, car dies. You will have to add an accessory switched relay in the sense line to the alt.
Visit www.madelectrical.com and read up on 3-wire connection. I believe this will cure your run-on and provide a better charging voltage.
Boy did I get hosed.... (long) chevypower Body Shop 65 Apr 24th, 07 12:10 PM
Which car would you buy? South Side Goons & Hitmen Bench Racing 10 Jun 23rd, 06 10:11 AM
Best Way to Locate a 69? camaromaniac Camaro Tech 16 Jan 11th, 06 08:10 PM
69' RS/SS 396 4-speed car VinMan Tag Team 19 Oct 30th, 05 07:59 AM
can't decide on color! thehugger Body Shop 15 Jun 18th, 05 07:19 PM
