1991 Camaro RS fuel problem - Team Camaro Tech
post #1 of 14 (permalink) Old Feb 4th, 07, 01:58 PM Thread Starter
Nathan
Send a message via Yahoo to greddyrcng
ok when i got the car i was told all it needed was a fuel pump....So i replaced the fuel pump ran fine for like one day...Then the next day went out side to start it and it didnt start so i listened for the fuel pump to hum no hum so i droped the tank again thinking it was something i done wrong with the wiring well nothing wrong...but still no start....so i tryed the relay...nothing...ecu...nothing...oil pressure sensor....nothing..but see here is the thing if i undo the positive wire on the batt let it reset the ecu then i will start but only for a sec and thats if the fuse is in the bypass....so i dont know what to do can anyone help me here?????
PS:1991 Camaro RS 3.1 V-6
greddyrcng is offline
post #2 of 14 (permalink) Old Feb 4th, 07, 02:13 PM
mike
Re: 1991 Camaro RS fuel problem
can you test for power at the pump connector???also did you change the filter.maybe you just got a bad pump
kustomwerker is offline
post #3 of 14 (permalink) Old Feb 4th, 07, 02:35 PM
mike
crap...i was just thinkin...maybe its a vats problem...is the security light on in the dash???sorry for the double post...
post #4 of 14 (permalink) Old Feb 4th, 07, 08:55 PM Thread Starter
Nathan
yeah it comes on for a sec then go's off...is that supposed to come on at all?
post #5 of 14 (permalink) Old Feb 5th, 07, 02:51 PM
mike
vehicle anti theft system interrupts the fuel flow so that the car cant be stolen without the proper key...check the resistor in the key...you can do this at the dealer...if its good, the problem is (and is most common)in the column in the wires connecting the ign switch contacts to the computer...you need to remove the steering wheel to repair this problem, but its a fairly easy fix...
post #6 of 14 (permalink) Old Feb 5th, 07, 04:32 PM
Fuel pump comes on for two seconds by the ECM when ign key is turned to IGN.
If you believe VATS may be the culprit, attempt to start the first time. Turn off, remove key. Wait 3-4 minutes, then restart using the same key. The engine should run till you shut it off. If this keeps doing the 3 minute trick then yes, you need a new switch tumbler under the steering wheel, as kustom suggests. Security light comes on as a 'bulb check' for one second.
post #7 of 14 (permalink) Old Feb 5th, 07, 05:04 PM Thread Starter
Nathan
is there a possibilty that its the isn switch?not the lock cylinder but the switch its self?
post #8 of 14 (permalink) Old Feb 5th, 07, 05:06 PM Thread Starter
Nathan
ign switch sorry
post #9 of 14 (permalink) Old Feb 6th, 07, 04:18 AM
Very well could be the electrical portion of the switch. All the connectors on the HEI plugged in?
post #10 of 14 (permalink) Old Feb 6th, 07, 05:50 PM Thread Starter
Nathan
what is the HEI?
post #11 of 14 (permalink) Old Feb 6th, 07, 07:06 PM
george
A VATS decoder would be nice in your arsenal of tools.If not,yank the steering wheel and look for the orange wire broken coming out of the ignition lock cylinder.Your Chevy dealer can read your key and supply you with the new coded cyl and the correct pellet to work with your VATS module.
fatblock is offline
post #12 of 14 (permalink) Old Feb 12th, 07, 07:55 PM Thread Starter
Nathan
Has Been Fixed
LOL.....i feel so dumb all it was was the wiring to the Oil Pressure switch had a lot of oil build up on it and need to be cleaned off so the relay could get a ground......
post #13 of 14 (permalink) Old Feb 13th, 07, 04:16 AM
Excellent! You might need a new sender if the one there is leaking/oozing.
post #14 of 14 (permalink) Old Feb 13th, 07, 12:43 PM Thread Starter
Nathan
i put a new one in and i think its the valve cover gasket but not sure yet but anyway i thank you for the help yall have helped me out greatly....
1990 Camaro Rs fuel filter/pump problem??? therisnotomorr0w Engine 1 Aug 11th, 05 04:00 AM
^9 Camaro Fuel Gage problem ambush904 Electrical & Wiring 0 Sep 6th, 04 05:51 AM
Fuel problem FASTENUFF Troubleshooting 1 Apr 2nd, 04 01:37 AM
fuel problem HELP jokerdwarf Troubleshooting 2 Dec 11th, 99 03:17 PM
