1990 toyota 4*4 - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 12th, 07, 07:26 PM Thread Starter
1990 toyota 4*4
clutch pedal stays on floor ,will not shift while running, shifts into gear fine while not running, slave cylinder on firewall full, any ideas?
martins 68 is offline
post #2 of 4 (permalink) Old Feb 12th, 07, 08:30 PM
ZZ_430's Avatar
Re: 1990 toyota 4*4
There is a bleeder on the slave cylinder.
You could try bleeding it, but it will probably need a new slave.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 4 (permalink) Old Feb 13th, 07, 10:56 AM
Vince
Re: 1990 toyota 4*4
The clutch masters are famous for leaking, if leaked itself empty and you refilled there is air in the line. If not the pressure plate sounds bad. More info; new clutch install or what? The first Toy 4x4s ........79-83 had the external slave as I recall
3forme is online now
post #4 of 4 (permalink) Old Feb 13th, 07, 12:42 PM Thread Starter
Re: 1990 toyota 4*4
turned out to be a hole ( rubbed by an ac hose) in the hose running from the reservoir to the slave. the oil leaked out ran down the hose to the exhaust. thanks for the help
Toyota Grand Prix of Long Beach Camaro Dave Bench Racing 8 Mar 28th, 06 01:30 PM
Toyota in NASCAR Uncle Tupelo Bench Racing 24 Jan 25th, 06 02:30 PM
Latest GM news - massive layoffs and plant closings! KevinW Bench Racing 17 Nov 22nd, 05 06:42 AM
Interesting article on GM and Toyota... CrossRamZ11 Bench Racing 21 Jun 16th, 05 06:52 PM
which car to through the 383 in?? 1990 or 1968 ?? Quick_68 Performance 11 Oct 4th, 02 02:03 AM
