problem - Team Camaro Tech
post #1 of 16 (permalink) Old Feb 13th, 07, 12:19 PM Thread Starter
don
problem
i may need a bigger fuel pump.i just put an lt4 383 stroker in my car.it also has the tpis dual 58mm throtle body kit on it.dont know what size injectors.i just put this in my 94 z28.it runs ok when it first starts but when i drive it an few mins it loses the power.i just have the stock fuel pump and i dont think it is enough.i want to put an inline fuel pump in so i dont have to drop the tank.has anyone had this problem and what fuel pump do you recomend?
mademan6889 is offline
post #2 of 16 (permalink) Old Feb 13th, 07, 04:03 PM
bill
Re: problem
first things first. what does the upgrade specs for fuel pressure on what you did. second what is factory pressure. if it all checks out good than need a pressure guage on the fuel to see if thats your problem of losing pressure. maybe a clogged cat converter for you to lose power
jaguareats is offline
post #3 of 16 (permalink) Old Feb 13th, 07, 04:23 PM
mike
Re: problem
could be clogged fuel filter...also, check the volume required for the new injection, but i would think that if the pump couldnt support the motor, then you would never have good power, not loose power after a few minutes...for an inline pump, you should remove the intank pump to remove the restriction, so dropping the tank is gonna happen one way or another...the filter is a cheap thing to start with...keep us informed...
kustomwerker is offline
post #4 of 16 (permalink) Old Feb 13th, 07, 05:38 PM Thread Starter
don
Re: problem
i dont know what i need but i know i need more fuel.it never seems like i have all it should.i know its not the cat cause i dont have one on my car.and i was told i can use an inline fuel pump with the one in the tank and that would give me what i need.
post #5 of 16 (permalink) Old Feb 13th, 07, 06:06 PM
bill
Re: problem
as me and kustom said need pressures and volume. all gm vehicles got a pump on motor early styles. later styles run out of fuel tank. or electric pump out of a fuel cell of which not factory. fords had a pickup pump in tank than a primary pump for the pressure.so your question to put an extra pump.i dont know never did it just put right pump where it belonged for the updated parts i put on a car.
post #6 of 16 (permalink) Old Feb 13th, 07, 07:30 PM
mike
Re: problem
some cars used what they called a "lift" pump to bring fuel at low pressure out of the tank, then a "pressure" pump to increase pressure to the desired amount for the motor...i dont believe you want to do that in your case...lift pumps are designed to flow alot of fuel at low pressure...your pump is designed to flow a specific volume and pressure, therefore you can only pull so much through it...you can get alot more gas to flow through a firehose than a gardenhose if i can use an offpage example...you would be trying to pull alot lo fuel through a gardenhose when you really need to pull a higher volume through a firehose...hope that helps...ps, there are alot of stock pumps that can put out 70 or so gpm...what r the sys req`s
post #7 of 16 (permalink) Old Feb 13th, 07, 07:51 PM
Harley
wiskeesour's Avatar
Re: problem
is the manifold temp sensor unplugged?
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #8 of 16 (permalink) Old Feb 13th, 07, 07:57 PM
mike
Re: problem
true...that would lean it out, but should also set the fan on right???i forget if it goes hot or cold, but believe it to be hot that the comp will read...
sometimes you`re the windshield and sometimes you`re the bug...
post #9 of 16 (permalink) Old Feb 13th, 07, 08:03 PM
Harley
wiskeesour's Avatar
Re: problem
if the sensor is unplugged or the element is cracked(during engine install), it wont turn the fan on.
Thanks Chief.
post #10 of 16 (permalink) Old Feb 13th, 07, 08:04 PM
Harley
wiskeesour's Avatar
Re: problem
i have also seen a knock sensor do this. It will give a false signal and retard the timing, and lean the motor out.......
Thanks Chief.
post #11 of 16 (permalink) Old Feb 13th, 07, 08:06 PM
mike
Re: problem
gotcha...tpis is the stand alone right???
post #12 of 16 (permalink) Old Feb 13th, 07, 08:11 PM
Harley
wiskeesour's Avatar
Re: problem
factory, no. aftermarket, some yes.
as afar as TPIS the product/company...I dont know ill have to read up on them.
Thanks Chief.
post #13 of 16 (permalink) Old Feb 13th, 07, 08:16 PM
mike
Re: problem
most of my experience is with oem stuff...i`m not real versed with aftermarket stuff...but when you unplug the temp sensor on an oem, the mil light goes on and the fan goes on...frason is the comp cant get a proven reading.fan goes on for protection...at least thats my experience...course, i been known to be wrong too...lol...
post #14 of 16 (permalink) Old Feb 13th, 07, 08:16 PM
Harley
wiskeesour's Avatar
Re: problem
I believe the actual TPIS product is a closed loop circuit, yes. But I am not sure have to read up on them. If it is, it narrows down the troubleshooting process......
Thanks Chief.
post #15 of 16 (permalink) Old Feb 13th, 07, 08:18 PM
Harley
wiskeesour's Avatar
Re: problem
i am not sure the fan has come on for me in the past when I unplugged the sensor, however the light did come on.
depending on the vehicle a 3K ohm resistor works WONDERS!
Thanks Chief.
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
Holley problem SICKT9 Engine 5 Jun 11th, 05 02:21 PM
BBC engine Vacume problem 68and69ss Troubleshooting 4 Jun 1st, 05 05:49 AM
arcing problem camaro-69ss Electrical & Wiring 2 Apr 6th, 05 08:59 PM
