Gas Pedal Sticking.... - Team Camaro Tech
post #1 of 20 (permalink) Old Feb 13th, 07, 05:01 PM Thread Starter
Dano
Just swapped in a 406 in the Camaro. I was running a 327 with an Edelbrock 1405 (I think), now running a Holley 4150 double pumper. I figured out where the piece on the threaded rod should be at WOT, but now my pedal pushes down and won't return. It feels like there is something restricting the pedal back to the correct height. I checked for plug wires/brake booster vac. lines in the way and couldn't see anything that would cause this to happen... I did notice a bolt that was a bit loose where the linkage by the firewall meets the rod for the gas pedal. I snugged it in, but no change... Any ideas???
Thanks-Dano
If you can't see the bright side of life, try polishing the dull side...
MrDanB is offline
post #2 of 20 (permalink) Old Feb 13th, 07, 05:10 PM
Re: Gas Pedal Sticking....
check for interference with the air cleaner housing.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #3 of 20 (permalink) Old Feb 13th, 07, 05:50 PM Thread Starter
Dano
The air cleaner sits a ways above the throttle mechanism on the carb. I DID notice that the return spring is a bit wimpy though. When I disconnect the threaded rod from the firewall linkage piece the pedal is "floppy" (no resistance) As soon as I hook up the rod to the carb the pedal pushes down then won't come back up and it felels like it is being wedged somehow... I wouldn't think that a spring would have to have pounds of pressure to return a pedal?!
Dano
MrDanB is offline
post #4 of 20 (permalink) Old Feb 13th, 07, 06:16 PM
Harley
wiskeesour's Avatar
take it loose at the carb and grab the throttle(on the carb), does the throttle at the carb still stick? Are the butterflies the culprit, or is it the throttle rod pulling the throttle over-center?
just guessin' of course.....
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #5 of 20 (permalink) Old Feb 13th, 07, 06:19 PM
Sean
Dan, thats a tough one to diagnose without seeing. I'd take the spring off and manually move it through its range of motion at the carb, check for any tightness or binding, then if you find nothing put the spring on and do it again. You may need the wife to push on the gas pedal as you watch things move, you just need to eyeball everything as it works.
I've seen the spring drag on the linkage of the carb at full throttle if its mounted too low at the stationary end (oposite of the linkage), that might do it, but you can bet it's somehow connected to the new carb unless the linkage at the firewall got bent during the engine swap.
You don't need crazy spring pressure, but it should be decent but not too heavy at the pedal for comfort, and a double spring for safety.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #6 of 20 (permalink) Old Feb 13th, 07, 07:30 PM
DjD
DjD's Avatar
Dan check for the alignment between the carb and the arm on the fire wall. Holley equipped small block 1st gens (Z/28) got a bent throttle rod where a Quadrajet got a straighter rod.
Holley:
Quad:
and the typical one I see used that can really bind sometimes...
...Dennis
DjD is offline
post #7 of 20 (permalink) Old Feb 13th, 07, 07:49 PM Thread Starter
Dano
You guys are great! Dennis, I have the infamous 'straight rod syndrome' lol
I will look into binding issues at the threaded rod. It sorta felt like binding or wedging at the pedal. Also, I need the throttle rod to have about 1/4"+ more threaded area to move the attaching do-hickey even further down... Thanks for the clues. I read some of your past postings on this and still couldn't find it, but the rod must be the culprit.... I'll post back what I find out on it..
Thanks-Dano
MrDanB is offline
post #8 of 20 (permalink) Old Feb 13th, 07, 07:51 PM
Jeff
When i replaced my heater core the the cables rubed on the throttle cable/rod inside of the car. It's someplace to look.
jeff_gates is offline
post #9 of 20 (permalink) Old Feb 13th, 07, 09:22 PM
Sean
Definately check that, but thats the rod I use with good results, so I guess you just never know.
Sean
68rs406 is offline
post #10 of 20 (permalink) Old Feb 14th, 07, 07:54 AM
Another thing to check is the plastic bushing that bolts to the firewall - the gas pedal rod passes through it. These are not that tough to break, esp when installing an engine. Shine a light down there and have a look. Mine broke last year. Kind of a pain to replace, but do-able with the motor in the car. You might also check to see if the pedal or rod is hanging up on the carpeting or somewhere else under the dash.
BPOS is offline
post #11 of 20 (permalink) Old Feb 14th, 07, 09:11 AM
Harry
dawg's Avatar
check your motor mounts too!
a bad mount will make the linkage stick before it lets go and then youll have a stuck full throttle!
434 stroker
US Navy retired
dawg is offline
post #12 of 20 (permalink) Old Feb 14th, 07, 03:57 PM
What about the small bolt that connects the throttle actuator to the rod. It goes through the part where the actuator is folded in two and the bolt clamps the actuator to the throttle pedal rod where it protrudes from the plastic bushing. If the bolt is installed upside down or something it may be interfering with the firwall or the bushing causing it to hang up.
dnult is offline
post #13 of 20 (permalink) Old Feb 14th, 07, 08:56 PM Thread Starter
Dano
Well, I tried to operate the pedal with different pieces of linkage disconnected and it seems like the pedal is fine with the threaded rod disconnected from the carb, but as soon as I attach it, the binding occurs. I am going to buy a bracket and cable system from Jegs or Summit and see if that helps. If NOT, then it's off to Pull a part and I'll grab a few different types of linkage rods and try those... Thanks for all the suggestions guys, I really appreciate it!
Dano
MrDanB is offline
post #14 of 20 (permalink) Old Feb 15th, 07, 03:55 AM
Make sure the ends of the rod, the stubs going into the linkage and pedal are parallel to each other. You may have bend the rod to keep these ends parallel.
The return spring should pull back the throttle and the spring should be perpendicular to the throttle shaft. It should not be at an angle, as this would pull the throttle askew and the throttle plates would bind in the bores.
Good luck & happy hunting.
post #15 of 20 (permalink) Old Feb 15th, 07, 05:03 PM Thread Starter
Dano
Found the problem!.... Looks like the pedal rod broke off where it meets the firewall linkage piece. I smell a new Lokar pedal and cable system in the near future for me.lol Thanks for all the help guys!!
Dano
Name:	DSCF0011 (Small).JPG
ID:	2633   Click image for larger version
Name:	DSCF0012 (Small).JPG
MrDanB is offline
Gas pedal has a mind of its own! Gehrkmania Camaro Tech 24 Jan 30th, 07 09:44 AM
Gas to Brake Pedal Distance Andrew69 Interiors 7 Feb 18th, 06 11:03 AM
brake sticking and pedal is also importkiller69ss Troubleshooting 3 Dec 25th, 05 09:14 AM
69 Z gas pedal 69Z28 Engine 6 May 23rd, 05 05:32 AM
Gas Pedal Assembly Speedy69 Restoration Corner 6 Apr 19th, 05 09:05 AM
