Vibration problem, ruled out wheels and tires - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 18th, 07, 01:13 PM Thread Starter
Bill
Hey all,
I have a 69Z I'm restoring. The car runs well, has the original muncie, and rear end. Currently when driving at speeds of 55+ the car begins to vibrate something fierce. I put the original rallies on with new tires and had them balanced. Could this be from the gear ratio and high RPM, or is it more likely from a possible unbalanced drive shaft? While removing interior I noticed dents and a puncture in the rear of the trans hump under the rear seat, looks like the drive shaft came off at one point.
Just trying to see if someone else has experienced this much vibration at this speed.
alexander is offline
post #2 of 10 (permalink) Old Feb 18th, 07, 01:43 PM
Re: Vibration problem, ruled out wheels and tires
the vibration is not normal. Easiest test is to get it going fast enough to vibrate, then kick in the clutch and let the motor go to idle. Vibration don't stop, problem is behind the clutch.
MY tunnel has some "dents" and a puncture exactly where your is, and exactly as you described. It happened on the strip last fall, after borrowing a set of et streets and sidestepping the clutch at 3500. The resulted in the pinion yoke becoming several peices, and the rear u-joint making a sudden unauthorized exit from the car. None of the guilty peices were ever found.
Unless you did it and know it is fixed right, I'd be very suspicious of that driveshaft. I'm putting a new rear in my car today as I type this, and what's left of my driveshaft will NOT be joining it.
post #3 of 10 (permalink) Old Feb 18th, 07, 02:41 PM Thread Starter
Bill
Jim,
I read your page, I'm impressed with the history. I'm a rookie. Ok just for clarification, with the clutch pressed in the RPM'S drop becuase the engine power is not engaged with the tranmission. Technically the drive shaft is still turning though. So if the vibration is still there, more than likely it is the drive shaft?
Man I've got a lot to learn.
post #4 of 10 (permalink) Old Feb 18th, 07, 03:37 PM
Rex
what kinda clutch are you running? What RPM is the vibration? I ask because I had one at 3200 rpm and it was my clutch. I had a centerforce clutch and at about 3000 rpms the weights open up, I changed the clutch...no vibration.
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #5 of 10 (permalink) Old Feb 18th, 07, 03:56 PM
Originally Posted by alexander View Post
Jim,
right, push in the clutch, driveshaft, trans, and clutch disk are still turning fast, flywheel, pressure plate & mtor slow down.
Could also try it in neutral, clutch out, this would rule out the clutch disk.
The trans itself is most likely not the problem, tho if the rear mount is separated, that could be it. You could try to lever the trans off the crossmember with a prybar to see if the mount is separated.
I'd still lean toward the driveshaft. With the car securely on stands, you could have someone run it up to speed while you watch it, just be careful.
I really need top update my webpage, it's 2 years old, since then, engine rebuild and stroked to 383, tko 500, last summers run to the rockies, and now she's down for new rear end, some floor work, 4 wheel disks, and a new front suspension.
post #6 of 10 (permalink) Old Feb 18th, 07, 04:34 PM Thread Starter
Bill
Ok. I'll try those ideas. Not sure about the type of clutch.
post #7 of 10 (permalink) Old Feb 18th, 07, 05:01 PM
For what it's worth, I would say driveshaft. I had the same problem even after new tires. Had the driveshaft balanced, vibration gone. Good luck.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #8 of 10 (permalink) Old Feb 19th, 07, 01:43 PM
Gary
Same problem, driveshaft.
69 Camaro convertible 327, TH 350, fully restored, well almost.
Gary Dorion is offline
post #9 of 10 (permalink) Old Feb 19th, 07, 01:58 PM
Robert
Could also be the pilot shaft bushing allowing the clutch to be off center when engaged. If this is the case it can be felt sitting still with trans in netrual clutch out and engine reved to the same rpm as when the vibs start on the road. If it vibrates this way sitting still, then push clutch in put trans in gear which causes the clutch to stay in place and rev to the same rpm. If the vibs are gone then it sounds like the bushing. Just something else for you to check, good luck.
Robert
TC member #18
rojo is offline
post #10 of 10 (permalink) Old Feb 25th, 07, 06:51 AM
http://csgbenefits.org/camarovibration.pdf
Try that .pdf document. It's all about tracking down vibrations. I've been fighting one in my car for a couple of years, but I'm pretty sure it's the driveshaft. I had car on chassis dyno and had guy underneath to look as I got it up to speed (about 80mph before mine kicks in).
Sometimes these can be elusive, so keep investigating. I don't think they gave all that much consideration to NVH (noise, vibration & harshness) back in the 60's, hehehhh
Dave F. in Rhode Island
Chevy-SS is offline
Help! Need Wheels 'n Tires quick! Seakane Wheels & Tires 10 Jan 11th, 07 09:49 PM
Biggest Wheels & Tires for 69 RS CONV. bbm Wheels & Tires 1 Nov 12th, 06 03:54 AM
Weird Vibration Problem Cameron Brakes, Suspension & Steering 11 Apr 19th, 06 07:18 AM
Are stock 70-1/2 Z-28 wheels & tires rare? trplblk Wheels & Tires 14 Sep 9th, 05 06:03 PM
Vibration with aluminum wheels Silver69Camaro Wheels & Tires 7 May 9th, 04 05:41 PM
