problem. - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 20th, 07, 01:02 PM Thread Starter
don
problem.
ok heres the deal i bought a 1996 lt4 383 stroker.i get it in the car and i hear a slight knock in the bottom end so i shut it right off.its either a rod knock or a spun bearing i know that.i need to know if anyone knows where to get the parts and part #s if you know.also how much.
mademan6889 is offline
post #2 of 7 (permalink) Old Feb 20th, 07, 02:40 PM
mike
Re: problem.
is it an auto...a loose tq conv bolt can sound alot like a rod knock...
sometimes you`re the windshield and sometimes you`re the bug...
kustomwerker is offline
post #3 of 7 (permalink) Old Feb 20th, 07, 02:44 PM
Re: problem.
Yikes... me think some exploratory surgery is in order first. She's gonna have to come apart so you can inspect those bearings.
383's could be built a few different ways. The mains for sure will be 350 size. The rods could either be 350 or 400, depending on which rods. Check the crankpins for scoring or other nastyness, and check the back of the bearing shells for a number. They could be marked 001 for slightly undersized to make up for wear (and the top and bottom halves could be different) or they could be marked 010 or 020 noting the crank has been regorund. You need to make sure you get the right bearings.
Also, they don't do this for no reason... tho running the motor out of oil is often reason enough. Still she's gonna need a teardown.
post #4 of 7 (permalink) Old Feb 20th, 07, 02:45 PM
Re: problem.
darned good point.
also possible for the bolts to hit stuff, or the flexplate to be in backwards causing bolts to hit stuff...
post #5 of 7 (permalink) Old Feb 20th, 07, 03:05 PM
mike
Re: problem.
cracked flexplate will do it too...but if not, jim`s always spot on...
post #6 of 7 (permalink) Old Feb 20th, 07, 03:32 PM Thread Starter
don
Re: problem.
it a 6 speed.and is there anywhere i can get a kit for 700 or less.
post #7 of 7 (permalink) Old Feb 20th, 07, 04:36 PM
Re: problem.
you need to get her apart and do some diagnoses before you start spending money.
Also, unless it's really bad, firing her up for an experienced ear to listen too would be a good idea. It's pretty easy to tell a rod knock, for example, much different than the regular tapping cused by an astray mechanical part.
As for what it will cost, that's gonna depend on what's wrong.
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
Holley problem SICKT9 Engine 5 Jun 11th, 05 02:21 PM
BBC engine Vacume problem 68and69ss Troubleshooting 4 Jun 1st, 05 05:49 AM
arcing problem camaro-69ss Electrical & Wiring 2 Apr 6th, 05 08:59 PM
