no power to starter - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 21st, 07, 05:00 PM Thread Starter
Julio
Unhappy no power to starter
Hi, Am having a bit of a problem on my 1994 chevy camaro with a 3.4 V6. My car won't start. I have check the battery and the starter and they are both good. What I did discover was that the purple wire going to the starter has no power when I try to start it. So I check the neutral safety switch and that is getting power and power is coming out when I turn the key to start it. now my ignition key is the one with the little medal piece on the key. I was wondering could my ignition switch be bad or is it something else. Thank you in advance. 94camaro
94camaro is offline
post #2 of 8 (permalink) Old Feb 22nd, 07, 06:35 PM
Re: no power to starter
If your not getting power to the starter (via the purple wire) but see power at the neutral safety switch, then I'd be looking for an alarm system that is interrupting current flow in the purple wire. Try taking an ohm measurement between the starter solenoid end of the purple wire and the neutral saftey switch. Sounds like you'll find there is an open circuit. Does this car have an after market alarm system on it?
dnult is offline
post #3 of 8 (permalink) Old Feb 23rd, 07, 03:54 AM
Security light on? If so, then probably an ignition key tumbler problem, the unit you stick the key into on the column. See what happens by attempting to start, then wait 3-5 minutes, then try again. If car starts, then I would suggest the ign tumbler be replaced. If not, then problem is elsewhere, follow dnult's suggestion. Do you have a Haynes service manual?
If the VATS (Vehicle Anti-Theft System) does not recognize the key, it will not close the no-start relay and the starter will not engage.
post #4 of 8 (permalink) Old Feb 23rd, 07, 10:08 AM
Jon
I know from experance, one time I tried to change out a radio on a 1994. When I went to remove the radio, the Camaro went into a lock and would not start. I don't know if that would help. But I have had it where the car locked itself down because I was changing out the radio. On some vehicles, if the thelf system is tampered with....they have to go to the dealership to unlock the thelf system.
2006 Siverado Hybird.
1968 Chevy Camaro.
1990 - 1994 US Navy.
jonm38 is offline
post #5 of 8 (permalink) Old Feb 23rd, 07, 10:20 AM
no car ever "has to go to the dealership" to get fixed.
a lot of the basic reasons this could happen might be in the owner's manual.
you don't plan sincerity.
novaderrik is offline
post #6 of 8 (permalink) Old Feb 23rd, 07, 03:15 PM
mike
vats interrupts the fuel i believe...i think it`ll be in the ign switch at the bottom of the column or possibly a relay, but you should take everetts advice and run down the schematic in haynes...dnults suggestion of the alarm is also a great point...
sometimes you`re the windshield and sometimes you`re the bug...
kustomwerker is offline
post #7 of 8 (permalink) Old Mar 1st, 07, 04:04 PM Thread Starter
Julio
hello to all, sorry about taking so long to respond. well I did what Dave(dnult) said and I found the ignition switch thanks to haynes manual, so now I have power to the ignition switch and power coming out after that power goes to the theft deterrent relay and thats where the power doesn't come out that relay has four wires a yellow which is powered when i turn the key a brown wire that comes from the neutral safety and that has power coming to and the purple wire that goes to the starter but has no power coming out, also a small yellow and black wire the goes to the theft deterrent module( what the hell is a theft deterrent module and does anybody know where it is located????) oh I know it not the relay because the hatch relay and theft relay are the same relay and I switch relays and the theft relay work when I connect it to the hatch connector...help am stuck please
94camaro is offline
post #8 of 8 (permalink) Old Mar 1st, 07, 06:29 PM
Ignition key have a resistor chip in it? The VATS module is located under neath or at the pass side toe board or kick panel.
If chip in key is not recognized by VATS module, then theft relay will not energize. There is a connector on column and two small gauge wires, white?, with key chip resistance to VATS module. If key is not read, usually because of key socket in tumbler, is not making contact with key. You should see with your meter the resistance value of the key chip. This key resistance value is compared inside VATS module and if a match is found, relay energizes, engine starts.
I think, yellow wire is relay power and yellow/black wire is power return. If you find ne resistnace from key socket, then you will have to have key tumbler changed. It requires steering wheel removal to change along with locking plate removal and turn signal removal and fishing of new wires from the same column connector at the bottom of the column.
But before you get the part, er, tumbler from any GM dealer, you need to show proof of ownership. Torx screwdriver is needed also. Study up from the Haynes manual. Tools to do the job can be bought from Harbor Freight for under $30. Patience is also needed.
400 starter jrager Engine 13 May 8th, 15 06:11 AM
Power Master Starter - Anyone have one? dschribs Engine 1 Jul 3rd, 06 05:32 PM
no power to the starter KURT Electrical & Wiring 8 Jun 26th, 06 05:16 PM
1994 Camaro and Power Windows wmartin Electrical & Wiring 1 Jun 9th, 06 04:17 PM
how do i install a push button starter switch palmdale420boy Electrical & Wiring 8 May 25th, 06 12:39 PM
