ignition switch - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 22nd, 07, 03:58 PM Thread Starter
Julio
Post ignition switch
Hello, I would like to know if there is any test that I can do to see if an ignition switch is good or bad? I have A 1994 chevy camaro with a V6 3.4 and I was wondering is there a way to test the ignition switch?
94camaro is offline
post #2 of 2 (permalink) Old Feb 22nd, 07, 05:44 PM
mike
Re: ignition switch
if you have no power to the momentary wire at the starter, its probably the ign switch...i believe its on the column by your go foot, and actuated by a bar from the key tumbler...look at the schematics in the haynes manual to see which wire is the momentary...(i dont know if its purple at the switch)...
sometimes you`re the windshield and sometimes you`re the bug...
kustomwerker is offline
Installing an AutoMeter Tach - Ignition Switch? robe9000 Electrical & Wiring 4 Apr 30th, 06 07:13 AM
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 10:59 PM
Ignition switch - help on identifying kfinsrud Troubleshooting 5 May 12th, 05 10:49 AM
Starting Issue -- Starts When Ignition Switch is Released from Start to On SteveN Troubleshooting 4 Oct 2nd, 03 04:46 PM
