1969 camaro rs headlight doors problem - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 29th, 09, 07:13 AM Thread Starter
Casey
Hopefully someone can help with the hidden headlight doors. The hidden doors were working beautifully and were aligned properly, opening and closing as they should. However, the other day my buddy came over to look at the car and he wanted to see how the doors open. When I started the car and pulled the light switch to open the lights, I felt the vacuum and then it had no vacuum--like someone had the other end of a rope and let go. I know the switch has to have vacuum on it and it worked properly before but now it has no vacuum. The car has been restored with proper lines, check valves, and headlight relay vacuum switch, all purchased from Rick's. The lines are run underneath the radiator support and everything appears to be tied in correctly. I have checked vacuum lines to see if anything was loose, but all is well. Looking for advice on what this problem could be and how to fix it.
casey0272 is offline
post #2 of 10 (permalink) Old Mar 29th, 09, 07:19 AM
Jeff
yellow69RS's Avatar
Re: 1969 camaro rs headlight doors problem
The is a "switch" on top of the vacuum tank for the doors, did your buddy move it?
Jeff
yellow69RS is online now
post #3 of 10 (permalink) Old Mar 29th, 09, 07:21 AM
click's Avatar
sounds like somebody flipped that switch as Jeff said.
click is offline
post #4 of 10 (permalink) Old Mar 29th, 09, 07:43 AM Thread Starter
Casey
There is a new headlight relay vacuum switch mounted on the vacuum reservoir, and the lines are run properly to it because it was working perfectly. How can I troubleshoot to see what the problem could be?
post #5 of 10 (permalink) Old Mar 29th, 09, 07:44 AM Thread Starter
Casey
Jeff...no, nobody touched anything. It worked, and then it didn't. The hood was shut. The lights came on, but the doors wouldn't open.
post #6 of 10 (permalink) Old Mar 29th, 09, 08:02 AM
William
William's Avatar
There is a sliding valve on the headlamp switch that alternates the side of the system that has vacuum. The valve has a metal tab that latches it to the plunger; the tab eventually breaks off rendering the system inop. It can be dismantled and replaced if you have another RS h/l switch. Be aware that factory gauge cars used a different switch.
William
CRG
William is offline
post #7 of 10 (permalink) Old Mar 29th, 09, 08:24 AM Thread Starter
Casey
Thanks, William and everyone. The head lamp switch is probably 40 years old, and like I said I started the car and pulled the switch to turn the headlights on. The lights came on, but the doors didn't open. I felt the vacuum pressure and then felt the pressure ease off on the head lamp switch. I've tried it several times now and there is no vacuum pressure on the head lamp switch on the interior driver's side (this is the switch that turns the headlights on and off, and opens the doors). I didn't know about a metal tab that could break off. Before I take this off to inspect, anything else? Thanks, Casey
post #8 of 10 (permalink) Old Mar 29th, 09, 08:27 AM
In the Tech section , tech reference #2 there is a system schematic. you should be able to trace back where there is, or is not ,vacuum by disconnecting the lines at the tank mounted valve and isolating the problem. ie. if there is vacuum coming from the headlight switch line when the switch is on, and none when it is off , then the switch is operating properly. if there is no vacuum going to the switch then the problem is in the hoses before the switch. etc.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #9 of 10 (permalink) Old Mar 30th, 09, 01:25 PM
The vacuum line could have come off the switch. I would check for vacuum at the switch if you have vaccum there, check downstream from the switch. If all is good up to there, then the vacuum relay is likely the problem. Problems downstream from the relay usually show up as one side or the other not opening, not both. Good luck!
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
post #10 of 10 (permalink) Old Apr 4th, 09, 06:48 PM Thread Starter
Casey
Hurray...I got a head lamp switch today from Rick's, installed it, and it works great. The switch was the original, 40 years old. Any ideas if these can be rebuilt? Thanks once again, Casey
