68 Headlight Vacuum Doors Won't Work - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 17th, 09, 10:22 AM Thread Starter
Question 68 Headlight Vacuum Doors Won't Work
Installed a new kit which included door assemblies, canisters, tank, hoses and installed new headlight switch. I put a vacuum gauge on the end leading into the intake and can generate 12" of vacuum but the doors will not operate. They opened when I pulled the switch but won't close even when I nudge them. Does it take morre vacuum or what? The car is completely restored and this is my last issue. Any help is greatly appreciated.
68rssskenp801 is offline
post #2 of 5 (permalink) Old Apr 17th, 09, 01:05 PM
TC
Re: 68 Headlight Vacuum Doors Won't Work
Make sure you have the one way check valve. I'm not sure, but if memory serves me right this can be the culprit. Others may know better and will chime in. also, when open try pulling the switch out on the vacumm tank and see if they close....they should.
1968 Camaro RS orig AC car, ZZ Fatburn, Doug's D368 Headers, Tremec TKO600 w/ Hurst Blackjack, 12 Bolt Posi 3:73 mulitleaf, SFC's, Budniks, Hotchkis, Magnaflow, etc
6Z8RS is offline
post #3 of 5 (permalink) Old Apr 18th, 09, 01:19 PM
Fred
Welcome Ken. Let me get this straight. You've done a complete restore without us?!
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 5 (permalink) Old Apr 18th, 09, 02:12 PM
Nick
Rarerat's Avatar
Dumb question, but you do have the relay valve on the supply tank in the open position?
Rarerat is offline
post #5 of 5 (permalink) Old Apr 19th, 09, 12:49 PM
Dale
Smile Re: 68 Headlight Vacuum Doors Won't Work
I do that a lot!!! Seems the valve gets moved 25% of the time I work on the car.
dale
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
