91 oil leak - Team Camaro Tech
post #1 of 3 (permalink) Old May 6th, 09, 12:31 PM Thread Starter
Question 91 oil leak
I have a 91 v6 rs and having an oil leak that im not sure where its coming from but i took some pics where it seems where its leaking from any info or advice would be great thanks
http://viewmorepics.myspace.com/inde...ageID=55816092
http://viewmorepics.myspace.com/inde...ageID=55816089
http://viewmorepics.myspace.com/inde...ageID=55816086
syndealer is offline
post #2 of 3 (permalink) Old May 7th, 09, 04:13 AM
BILL
SPARKY69's Avatar
Re: 91 oil leak
Intake-valve covers??? Cant see all that good??
SPARKY69 is offline
post #3 of 3 (permalink) Old May 7th, 09, 06:05 PM
Re: 91 oil leak
Many of us have crawled around underneith looking for an elusive oil leak only to find a little dribble from a valve cover has found it's way to a dripping-off point down below (as Bill stated). So don't overlook that - it can boggle the mind.
Otherwise I'd suspect your oil pan / timing cover may be leaking. Perhaps the fuel pump push rod bolt hole is open. Timing cover could be it, or perhaps oil has found it's way between the crank snout and the damper.
dnult is offline
