# 8 plug fouled - help!! - Team Camaro Tech
post #1 of 13 (permalink) Old May 17th, 09, 03:41 AM Thread Starter
68z
I have a 68Z and had a guy put electronic ignition in which is nice. However, I put about 50 miles on the car and noticed a backfire. I pulled each plug and noticed #8 cylinder plug was fouled and corroded. I put a new plug in, it ran like a champ. After 100 miles or so the same plug was fouled and corroded. I noticed # 3 & #7 cylinder plugs were corroded too , but not as bad as #8.
Any idea what may be causing this? I don't think I had this problem when the conventional points/condenser were in there.
please help and thanks!
TR
tr68z is offline
post #2 of 13 (permalink) Old May 17th, 09, 06:58 AM
Camarodude67
Re: # 8 plug fouled - help!!
Hi TR, is this a traditional HEI system or MSD?
Jeff G.
69 Vert
camarodude67 is offline
post #3 of 13 (permalink) Old May 17th, 09, 11:45 AM Thread Starter
68z
it is called pertronoics ignitor.
tr68z is offline
post #4 of 13 (permalink) Old May 17th, 09, 01:42 PM
Howard
IMHO check the plug wires or switch #8 wire to a new one and see if it helps.Wires can go bad w/o any visual signs.
Just Having fun with all My Big Block Toys!!!
bbmusclecars427 is offline
post #5 of 13 (permalink) Old May 17th, 09, 04:30 PM Thread Starter
68z
I put a new set of 7mm wires on already....no different.
tr68z is offline
post #6 of 13 (permalink) Old May 17th, 09, 11:22 PM
Levi
How old is the motor? I know gm designed intakes to pull vaccum off the 8th cylinder, and there usually the first to wear out. Is your car a automatic?
1975 Camaro "Black Out"
.Bad75. is offline
post #7 of 13 (permalink) Old May 17th, 09, 11:37 PM
Is the distributor cap and rotor new? Check the inside of the cap and the rotor real good. Look for any carbon deposits, especially on the #8 post. If there are any issues, try another cap......Jb
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #8 of 13 (permalink) Old May 18th, 09, 06:06 AM
mccorry's Avatar
Yes.... what do you mean by corroded and fouled?
What does the plug look like? Oily? Soot coverd? Rusty (iron oxide)?
Steve -
'69 Camaro RS/SS-350, TH350, factory air, factory AM/FM, factory tilt wheel, console w/ gauges - Daytona Yellow
- 1969 Van Nuys Camaro Database
mccorry is offline
post #9 of 13 (permalink) Old May 18th, 09, 07:06 AM
Auto trans ? check the trans fluid level if it is low the transmission modulator has a torn diaphram and you are sucking in trans fluid right into #8. Next guess is that he loosened off the intake bolts to RE & RE the distributor, gasket is now leaking, oil being sucked in from lifter valley.
Rob.Canada is offline
post #10 of 13 (permalink) Old May 18th, 09, 05:58 PM Thread Starter
68z
z-28 ----> standard transmission
motor is a CEB block ..installed in 1972
tr68z is offline
post #11 of 13 (permalink) Old May 18th, 09, 05:59 PM Thread Starter
68z
standard trans
tr68z is offline
post #12 of 13 (permalink) Old May 19th, 09, 05:36 AM
mccorry's Avatar
Got your PM and just replied.
It definately sounds like you've got a piston ring / bore or head gasket issue. Could also, potentially, be a bad valve guide.
Steve -
mccorry is offline
post #13 of 13 (permalink) Old May 20th, 09, 07:54 AM
12 volts to the distributor rather than the 8 volts through the resistor wire?
deerhunter is offline
