89 IROC Fuel Problems? - Team Camaro Tech
post #1 of 3 (permalink) Old May 20th, 09, 08:53 AM Thread Starter
Angry 89 IROC Fuel Problems?
Okay i have an 89 IROC 350 TPI and have replaced the starter, the fuel pump, the fuel pump relay, and the Ignition Control Module, and i still can't figure out why my brand new pump will not turn on. We tested the pump before we put the tank back in and it worked fine. I also tested it before i put the axle back together after we put the tank in and now it won't work i don't get it. Any help is apreciated
Jared1418 is offline
post #2 of 3 (permalink) Old May 20th, 09, 11:02 AM
BILL
SPARKY69's Avatar
Re: 89 IROC Fuel Problems?
are you pinching the wires when your putting it back in!!
SPARKY69 is offline
post #3 of 3 (permalink) Old May 20th, 09, 01:24 PM
Tom P's Avatar
Assuming the ECM, relay, pump,etc are OK, try checking connections to the Oil Pressure Switch
If that comes unplugged, or is bad, no signal will get to the fuel pump from the ECM.
This is a safety feature: If the engine has no (low) oil in it, it will shut down the Fuel Pump to save the internals..
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
