350 engine diesel noise/rattle/preignition noice - Team Camaro Tech
post #1 of 5 (permalink) Old May 21st, 09, 08:10 AM Thread Starter
I have developed a horrible sound coming from what sounds like the front of the engine. The motor runs fine at idle (constant and good RPMs, vacumm, fuel pressure, oil pressure) but as soon as you give it a bit of gas, it sounds horrible (like preignition pings x 10 and/or a diesel engine). The timing is set at what its always been at (8 degrees) and I cant find any belts or pulleys that are loose. The carb was switched out to ensure to wasnt a mixture issue. I thought it could be a rod or bearing ready to let go however I have driven it for about 200 miles and it still seems to run fine, just a horrble sound. I have gotten pissed several times and dumped the clutch at some insane RPMs but cant seem to lunch the engine (if its bad). Could it be a lose timing chain? Any thoughts would be appreciated.
wheezer is offline
post #2 of 5 (permalink) Old May 21st, 09, 09:14 AM
Harry
dawg's Avatar
Re: 350 engine diesel noise/rattle/preignition noice
yeah timing chain jumps a tooth or two.
434 stroker
US Navy retired
dawg is offline
post #3 of 5 (permalink) Old May 21st, 09, 04:55 PM
george
Sounds like you may have a cracked piston skirt.See if you can quite it down and isolate it by removing secondary ign volts one at a time at the spark plugs.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 5 (permalink) Old May 21st, 09, 10:47 PM
Steps
Mechanics sethoscope..they are cheap, and also put the car on a hoist and check from underneath.
Steptoe is offline
post #5 of 5 (permalink) Old May 22nd, 09, 04:40 AM
Harley
wiskeesour's Avatar
I agree, piston skirt.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
