brake pedal sticks - Team Camaro Tech
post #1 of 7 (permalink) Old May 22nd, 09, 10:01 PM Thread Starter
brake pedal sticks
hi all, 69 camaro z disc front dr. rear. brake pedal sticking when running, can take it off w\toe. if i pull vac line off it works fine. car sat all win while i rebuilt frt, end. am at my wits end. have replaced master cyl., both rubber lines, and booster. took 3 eighths off old rod and fixed it till you start it. left frt wheel is the one sticking, even put a new cal. on it today knowing it prob. wouldnt fix it . after running can pull line and hear air come out of booster. do not want to put return spring, hasnt had a spring for the 27 yrs ive owned it. did install new intake but line is getting vac. HELP PLEASE
kmejr is offline
post #2 of 7 (permalink) Old May 23rd, 09, 07:08 PM
Skip
Skeeter55's Avatar
Re: brake pedal sticks
Hows the spindle look, is it bent and hanging up.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 7 (permalink) Old May 23rd, 09, 07:28 PM Thread Starter
spindle seemed fine , wheel rolls free when you take up brake ped. w\ your toe. only change ,besides whole engine comp. gutted over winter is the victor jr. i put on. when new booster didnt fix prob. i then got mast. cylinder ,whats really weird is that fixed everything and drove to my dads and back. next day problem back . can a booster go bad that fast. booster is cosmeticly just like my old delco unit that i kept because of the 9204 stamp thank you for reply
kmejr is offline
post #4 of 7 (permalink) Old May 23rd, 09, 07:33 PM
Skip
Skeeter55's Avatar
Which booster and master.... What hole is the pedal rod in, is it adjustable in upper or lower and the rod from the booster to the master may also be the problem if its not long enough... Was this a kit.
post #5 of 7 (permalink) Old May 23rd, 09, 09:02 PM Thread Starter
not a kit , booster says oem repl. made in mehico. master is a federated says rebuilt made in usa. only have 1 whole, freeplay is good. rod was same length on both. but mast. is short right looking 1 but no side bleeders . i tried shortening rod per booster instructions as said too long could cause sticky pedal it made sense. now im thinking u may be right and need to lenghten rod i cut up. that would make pedal come back up. i rebuilt every sevicable piece on frt. end and redid engine bay. it just goes to show no good deed goes unpunished. might try old boos. tomorrow. turned in old mas. so cant try it.
kmejr is offline
post #6 of 7 (permalink) Old May 24th, 09, 08:18 AM
Skip
Skeeter55's Avatar
There you go,
They also make an adjustable pedal rod if you need it PM me... Frank is were i got mine. https://www.camaros.net/forums/member.php?u=15238
post #7 of 7 (permalink) Old May 30th, 09, 09:33 PM Thread Starter
brake stick fixed, rod needed about eighth inch off to match booster at rest pos. also the sleeve that pedal connects to up under dash had gotten gummed up from all the sanding and grinding i did in eng. comp. should have had hole masked off. w-deed it real good and worked pedal off and on. lastly new booster had a lot of (packing junk) where it met firewall ,picked a bunch of it out around the rod to free it up ,thank u skeeter and all who looked at post to try to help. kmejr
kmejr is offline
