87 iroc w/mass air sensor problems? - Team Camaro Tech
post #1 of 6 (permalink) Old May 25th, 09, 11:57 AM Thread Starter
Unhappy 87 iroc w/mass air sensor problems?
i have an 87 iroc with a 350 tpi. it all of the sudden started running rough and stalling out on me. It eventually wouldn't even start. It spit code 33 (mass air) so i replaced the mass air, and it still did nothing. I can unplug the mass air, and it will start right up, eventually stalling out.. When you start it (with the mass air unplugged) , you can plug the mass air back in, turn the car off, and start it right up like nothing is wrong. You turn the car off n wait 5 or 10 minutes, and it won't start again. Same with the MAF sensor. You can unplug it, and it starts, you plug it back in and turn the car off for a minute and it won't start back up. I am hoping it's not the ECM since code 33 does mention that it might be defective. I don't want to take it to a mechanic because they will just jerk me around. My stepdad is the one who built this car, and he is just clueless when it comes to this. We have read the camaro book up and down, and still can't figure this out. This car only has 65k original miles on it. I really think its worth the hassle to fix it, I just can't seem to figure this out on my own. Any help would be greatly appreciated! Thanks in advance.
ftballmastr49 is offline
post #2 of 6 (permalink) Old May 25th, 09, 01:45 PM
Re: 87 iroc w/mass air sensor problems?
I would say to clean the MAF sensor using a sensor cleaner and make sure there are no holes/leaks in the bellows between the throttle body and MAF sensor.
Might even remove the IAC and clean its passage it sits in.
Of course, you've looked for other intake leaks?
Fuel pressure regulator hose is dry on the inside when you pull it off?
post #3 of 6 (permalink) Old May 25th, 09, 03:14 PM Thread Starter
I did everything you said, and it still doesn't want to start. only if i unplug the mass air. There are no leaks what so ever, and the problem is still there.... anymore suggestions??
post #4 of 6 (permalink) Old May 25th, 09, 06:16 PM
Here is one my prior posts on MAF problems that may help.
Check the connector pins on the MAF. A friend of mine had one where the socket pins were spread open and enough corrosion (more like a dull film) developed to create a bad connection. It took him 3 MAF units (luckily the autoparts store accepted them for return) before we looked at those pins. We buffed the connector pins with a tiny bit of sandpaper, tightened them up with a pick probe and doped them with dielectric grease. The way we found the problem was by back-probing the MAF signal line and saw it was stuck on 5 volts.
dnult is offline
post #5 of 6 (permalink) Old May 26th, 09, 12:18 PM
Steiner
I had the same contact problem on my S10 coil.
You can buy a used ECM on ebay for $50. I've got one for my truck that I sent off to have tuned and keep my original for a spare.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 6 (permalink) Old May 28th, 09, 09:09 AM Thread Starter
thank you all for all of your advice, i really appreciate it. i still can't seem to figure this out. Looks like mechanic here i come... I found this "corvette dr." and 87 corvettes basically have the same tpi setup i guess?
Tags
350, iroc z28, mass air sensor, stalling at idle, starting
