02 SS idles rough and stalls when put in gear - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 18th, 09, 08:00 PM Thread Starter
I have a 2002 SS Camaro that idles really rough. It kind of surges when it idles.When I put in gear It wants to die. I recently charged the battery and when it was on the charger and running it seemed to idle a lot better. Anybody have a Idea?
Thanks Mark
MACD24 is offline
post #2 of 6 (permalink) Old Jul 19th, 09, 01:25 AM
Andreas
Re: 02 SS idles rough and stalls when put in gear
Idle learn procedure maybe.....just an thought, this link is for LS engines.
http://www.hotrodlane.cc/New%20LS%20...0Procedure.htm
Camaro 1969 ProTouring, LS2/T56, Art Morrison Subframe, Chris Alston G-link.
Chevrolet Nova 2DR/HT 1967 (under construction)
Chevrolet Bel Air 1957
Pontiac G8 GT 2009 (daily driver)
Firehawk-Adde is offline
post #3 of 6 (permalink) Old Jul 19th, 09, 10:04 AM
BILL
SPARKY69's Avatar
Originally Posted by firehawk-adde View Post
idle learn procedure maybe.....just an thought, this link is for ls engines.
http://www.hotrodlane.cc/new%20ls%20...0procedure.htm
x2...let us know if that fixed it?
SPARKY69 is offline
post #4 of 6 (permalink) Old Jul 19th, 09, 11:44 AM
Skip
Skeeter55's Avatar
Thanks Mark
It idle better while you had it on the charger, then check the alternator and make sure its not running off the battery.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 6 (permalink) Old Aug 7th, 09, 09:48 PM Thread Starter
Sorry To take so long to get back. The Idle Learn Procedure worked. Saved by Team camaro again.
Thanks Mark
MACD24 is offline
post #6 of 6 (permalink) Old Aug 8th, 09, 10:47 AM
The idle relearn is pretty dramatic on those LS engines (probably more of an OBDII thing). I changed the battery in mine last year and thought something was seriously wrong with it the first time I started it. But after going through the relearn it runs like a champ.
dnult is offline
