86' not starting - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 5th, 09, 06:33 AM Thread Starter
Unhappy 86' not starting
i have an 86' z-28 v8 carbureted, camaro. I went out this morning to start it for work but it wouldn't start, like the engine was getting no spark, we put starter fluid and tried to jump start. the battery seems to be working fine and i tried to full throttle it, the gas may not be reaching the carburetor?
lane19 is offline
post #2 of 3 (permalink) Old Aug 5th, 09, 07:11 PM
Re: 86' not starting
Carberated 86? I thought they were all either TPI or throttle body injected. What about an ECM? Do you have a mechanical fuel pump mounted the the right side of the block near the front?
dnult is offline
post #3 of 3 (permalink) Old Aug 9th, 09, 05:53 AM
J.J.
Send a message via AIM to jj69z28
fuel pump relay, in tank pump, fuse for the ECM
Rally Green 1969 Camaro Z/28
jj69z28 is offline
Tags
86 camaro, carburetor, starter problem
