1998 3800 wont rev past 2500 rpm - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 5th, 09, 07:23 PM Thread Starter
i have a camaro with the v6 3800 i changed the fuel filter cleaned maf and fuel press reg was ok put in a new coolent sncr the car ran like crap this morning but i check the fuel reg put it back together it ran fine went to town put the ac on it all started over again this time i have no cure can i please get some help
tiawahjack is offline
post #2 of 10 (permalink) Old Aug 5th, 09, 07:42 PM Thread Starter
i checked and cleaned maf sncr changed fuel filter checked fuel press regulator checked for vac leaks im stumped it ran great for about an hour today then i turned the ac on it all went down hill been messed up sence oh i replaced thermo scnr on the front of the motor under maf scnr and new gas
post #3 of 10 (permalink) Old Aug 5th, 09, 07:54 PM
Steiner
Re: 1998 3800 wont rev past 2500 rpm
If you've been working with the fuel system or had a bad coolant sensor to start with and possibly got a lot of fuel through it, it sounds like the catalytic converter. A bad coolant sensor will often make it run rich. Will it not rev past 2500 in park, in gear, or both? Does it idle fine and run fine up until you hit a certain RPM? A failed catalytic will stop the exhaust up so it can't rev up under load.
I had a truck once that the rotor went out in the distributor while I was traveling between Statesboro, GA and Nashville, TN. I had to leave it at a dealership in Atlanta and get a company car to get to Nashville. Luckily, my company was in Atlanta. The dealership called me and told me that the computer was telling it to dump too much fuel in because they pulled a spark plug and it was pumping fuel out of the cylinder. I asked him, "Doesn't that sound like no spark? Why don't you try changing out the cap and rotor?" Unbelievable. So, they changed those out and it ran. When I was able to pick it up, it wouldn't rev past 3000 because all the raw fuel they pumped through it while monkeying around melted the converter and the exhaust couldn't flow.
So, long story short (too late), sniff the exhaust. If it smells like rotten eggs, it's the catalytic converter. Mine didn't really smell though so who knows.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 10 (permalink) Old Aug 5th, 09, 08:00 PM Thread Starter
thanks for the repli iwill c about the cat in the morn it starts and idles fine revs up to 2500 and then bogs down wont rev any higher same n park or in gear
post #5 of 10 (permalink) Old Aug 5th, 09, 09:03 PM
Dale
Check engine light on? If so what codes? How much fuel pressure?
Does it run well up to 2500rpm?
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #6 of 10 (permalink) Old Aug 5th, 09, 09:39 PM
could be that the switch on the shifter or trans or wherever that tells it what gear it's in might have gone bad or out of adjustment. they are set up with a rev limiter for when the car is in park.
you don't plan sincerity.
novaderrik is offline
post #7 of 10 (permalink) Old Aug 5th, 09, 10:21 PM Thread Starter
thanks for the repli there is no codes and its not throwing any i have a tech2 reader that i keep looking for codes with wishing it would throw a code so i got a place to start not sure about fuel pressure i will check it to in the morn i got a chiltons book to c what the pressure pose to be thanks again
post #8 of 10 (permalink) Old Aug 5th, 09, 10:33 PM Thread Starter
thanks for the repli i will check into that but its not rev limiter sound this just loads up bad rev it up to 2500 bogs let off throt and rev again it goes up to 2400 and then 2300 another thang when i turn a/c on the rpm surge down and about 400 rpms
post #9 of 10 (permalink) Old Aug 6th, 09, 02:52 PM Thread Starter
fixed it we have a winner it was the cat conv thanks for your help
post #10 of 10 (permalink) Old Aug 6th, 09, 06:41 PM
Steiner
Cool! You're welcome.
'69 Camaro
500hp/538lbft
Steiner is offline
