Engine stumbles then falls flat...embarassing. - Team Camaro Tech
post #1 of 20 (permalink) Old Aug 21st, 09, 04:54 PM Thread Starter
Louie
rad454's Avatar
I have an old corvette that I have been noodling around with for many years. My 69 Camaro is my main focus but the vette is fun, if not irritating to drive at times.
The problem with it is that after warming the engine up and letting it sit, it wont idle. (454, 650 Holley spreadbore, stock 390 HP cam, exhaust, distributor, 4 speed) I drive it for about 45 minutes and it warms up, drives and idles perfectly. Vacuum is steady at 20 and it idles right at 700 rpm's. But after it sits for a while I get in it to do some more driving and the engine will not idle. It stumbles and the only way to keep it going is to keep the idle up with the accelerator pedal. I replaced the stock Quadrajet with the new Holley because it did the same thing. I thought I had solved my problems.
I am pretty sure it's fuel related but cant nail this problem down. I have a similar engine going into the Camaro and if this happens to it too, the garage must have been built over an old cemetery.
Anyone have any ideas?
69 SS/RS Fathom Green 454 4 speed
Bumper sticker- My other auto is a .45
rad454 is offline
post #2 of 20 (permalink) Old Aug 21st, 09, 05:01 PM
Skip
Skeeter55's Avatar
Re: Engine stumbles then falls flat...embarassing.
Sounds like the advance plates in the dizzy are sticking. Is it vacuum advance dizzy, make sure its advancing. Could also be the vacuum can.... I'm only pointing to the dizzy because you already tried another carb and it did the same thing.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 20 (permalink) Old Aug 21st, 09, 05:21 PM Thread Starter
Louie
rad454's Avatar
Skip, The vacuum can is new, but I will try spraying the weights and internal springs with a lite coating of silicone spray. Hadn't thought of the dizzy since this always occurs at operating temps (190 degrees).
rad454 is offline
post #4 of 20 (permalink) Old Aug 21st, 09, 05:27 PM
Skip
Skeeter55's Avatar
What about a fuel vapor lock at temp... Is the fuel boiling over and down the carb when you shut it off (look down the carb right when you shut it off), are the floats adjusted and is the carb cleaned (jets, needle seat, air bleeds).
post #5 of 20 (permalink) Old Aug 21st, 09, 05:42 PM Thread Starter
Louie
rad454's Avatar
I don't think the fuel is boiling (vapor lock?) because the problem occurs after it has been sitting and cooled off (weird) Seems like it is starving for fuel by the stumbling, barely idling sound of the engine.
rad454 is offline
post #6 of 20 (permalink) Old Aug 21st, 09, 05:47 PM
Banned
Ron
Badbird's Avatar
Try by passing the throttle restrictor valve from the throttle functioning plate or it could be an electrode malfunctioning in the ***** valve!
Badbird is offline
post #7 of 20 (permalink) Old Aug 21st, 09, 05:50 PM
Skip
Skeeter55's Avatar
OK now where getting some where. I'm just picking your symptoms, but have you been reading your spark plugs. If your having a lean stumble then your plugs should be almost white and crusty depending on how old the plugs are.
post #8 of 20 (permalink) Old Aug 21st, 09, 06:00 PM Thread Starter
Louie
rad454's Avatar
New plugs, and they are tan/brownish except...the #2 cylinder which is usually black (oily).
rad454 is offline
post #9 of 20 (permalink) Old Aug 21st, 09, 06:04 PM
Skip
Skeeter55's Avatar
Louie if your hold down the gas peddle to keep it running when its warmed up. Then it sounds like a vacuum leak or even a bad coil. I'm just guessing but this bad coil has happened to me for weeks until i found the problem.
post #10 of 20 (permalink) Old Aug 21st, 09, 06:19 PM Thread Starter
Louie
rad454's Avatar
Skeeter, how did you trouble shoot the coil? Don't have a back up I can throw on there.
rad454 is offline
post #11 of 20 (permalink) Old Aug 21st, 09, 06:21 PM
Skip
Skeeter55's Avatar
My luck it went completely dead with no spark, so i replaced it with my old MSD and it fired right up. I don't think you can check a coil but just buy a new one. Coils will act funny and do some strange things, you know you are getting spark but when the coil get hot your motor doesn't want to idle. That can be a coil.
post #12 of 20 (permalink) Old Aug 21st, 09, 06:43 PM
george
How are you firing this off?Stock style points and condenser?
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #13 of 20 (permalink) Old Aug 22nd, 09, 05:30 AM
Harry
dawg's Avatar
a 650 holley on a 454 is quite small.
but one issue would be the engine isnt getting enough pump shot.
if you install the bigger pumpshot housings and arms youll wake that sucker up.
I had same issue with my 406 last spring until I changed accelerator pumps.
car not burns tires from a standing start.
also as mentioned before is the weights in the distributor.
if they are sticking itll cause similar symptoms.
434 stroker
US Navy retired
dawg is offline
post #14 of 20 (permalink) Old Aug 22nd, 09, 08:20 AM Thread Starter
Louie
rad454's Avatar
George, the dizzy was upgraded to a Pertronix pointless system.
I am thinking back a year ago when it did this same thing. I was cruising down I-5 around 65MPH and exited the interstate to get back home. I rolled up to the stop sign and the engine (after running flawlessly for the past hour) just stumbled and died. This was the beginning of the quest to figure out how a BB could be running perfectly and then due to time/temp, simply give up the ghost.
When I get this figured out I'm thinking it will be something very simple like a semi plugged fuel filter or as skip mentioned a sticking distributor weight.
I'm gonna hit it again this morning and see if I can duplicate the problem. Thanks for the input.
rad454 is offline
post #15 of 20 (permalink) Old Aug 22nd, 09, 03:21 PM
Harry
dawg's Avatar
It could also be fuel percolation problem or a vacum in the gas tank.
things to check!
434 stroker
US Navy retired
dawg is offline
