1976 Door Problem - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 26th, 09, 10:03 AM Thread Starter
1976 Door Problem
I shut the drivers door 10 years ago. It has not opened since. How can I get it open without bending the door or body up? I'm getting tired of going in and out the window.
1976LT is offline
post #2 of 3 (permalink) Old Aug 26th, 09, 01:58 PM
Harris
Re: 1976 Door Problem
Get the inner door panel off and see if you can release the door latch with a long screwdriver.
Or possibly pull the outer window fuzzie and use that long screwdriver from above down into the door.
h-bomb is offline
post #3 of 3 (permalink) Old Aug 26th, 09, 04:09 PM Thread Starter
Thanks for your help, I can't (without tearing it up) take of the inner door panel because the edges go behind the door jams when the door is closed. Going through the window fuzzie seems to far down, and I can't see the latch from there. I am thinking (If no one has a better idea) tearing the door panel, but I really don't want to do that. But I guess I could.
1976LT is offline
