1968 camaro 350 2 barrel - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 11th, 09, 08:42 PM Thread Starter
aldo
while driving and idling i am picking up a fuel odor, and i cant find a leak, any ideas would help, thanks in advance
aldo boselli is offline
post #2 of 7 (permalink) Old Nov 11th, 09, 10:55 PM
Tim
Re: 1968 camaro 350 2 barrel
Follow the fuel line back to see if it is wet. It could be the top of the tank has a pinhole. Or sending unit gasket. Rubber line that connects mainline with sending unit.
Just some thoughts.
Trick1 68rs 454 4sp 12blt
Trick1 is offline
post #3 of 7 (permalink) Old Nov 12th, 09, 12:19 AM
mark
If you can't find a leak and smelling fuel carb might be running to rich. mark
stroud6 is offline
post #4 of 7 (permalink) Old Nov 12th, 09, 12:40 PM
Mickey
Moonpie's Avatar
Check pinhole on fuel pump to see if diaphram is leaking. Check exhaust pipe to see if is sooty to confirm running rich.
Moonpie is offline
post #5 of 7 (permalink) Old Nov 13th, 09, 08:52 AM
There is a little metal cover inside the trunk below the latch plate that can be removed to inspect the rubber coulpling around the filler neck. If you have a black light, try using it to find fuel stains. Fuel stains won't glow but will have a yellowish appearance that stands out from the rest of the grime.
dnult is offline
post #6 of 7 (permalink) Old Nov 19th, 09, 01:30 PM Thread Starter
aldo
thank you all for the suggestions, i will get on it tonight
post #7 of 7 (permalink) Old Nov 19th, 09, 01:55 PM
BILL
SPARKY69's Avatar
check the fuel line going to the carb it might be leaking there and evaporating and you cant see the leak,just look for stains on the intake area..
SPARKY69 is offline
