'89 Camaro RS problems - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 19th, 09, 06:51 PM Thread Starter
Richard Devries
Hello need help. 2 problems. trying to resurrect '89 Camaro RS. Starter only engages when jumping silinoid. Also, fuel pump runs for 4 sec and then stops no fuel to Throttle Body. Are problems related or whats fix for fuel pump? Thanks, Ricscamaro
Ricscamaro is offline
post #2 of 6 (permalink) Old Dec 19th, 09, 08:57 PM
DONNIE
Re: '89 Camaro RS problems
sound like ignition switch,does it have anti theft?
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
67CAMAROSS is offline
post #3 of 6 (permalink) Old Dec 19th, 09, 09:40 PM
The ECM will run the fuel pump for a couple of seconds after the switch is turned on to prime the system. Beyond that, the ECM needs to see pulses coming from the ingition module before the fuel pump will be turned on. If the engine isn't cranking and / or the ignition module isn't feeding pulses back to the ECM, the fuel pump won't run.
I'd focus on the cranking issue first. Are you getting 12V to the solenoid when you crank it? If not, is the ignition switch providing 12V when cranking? The answer to these two questions will narrow down the possibilities considerably. Do you have a security system that may be interrupting power to the solenoid?
dnult is offline
post #4 of 6 (permalink) Old Dec 20th, 09, 09:15 AM
William
William's Avatar
I also have an '89 RS. The neutral safety switch can be a source for this kind of problem.
William
CRG
William is offline
post #5 of 6 (permalink) Old Dec 20th, 09, 03:47 PM Thread Starter
Richard Devries
thankyou for your replys.Tried changing out ignition switch with new, no change.How would i test neutral safty switch? tried starting in park and neutral and then all positions.
Only anti theft is chipkey as far as i know. have original key as far as i know.will check silinoid next. where is it? behind kick panel on drivers side? thanks RicD
post #6 of 6 (permalink) Old Dec 24th, 09, 12:08 PM
col
have you thought about haveing the ECM flashed? might be something in your ECM have a crack attack. my chevy did that to me once and i spent alot of money chasing my tail and ended up with an empty wallet and my **** in my hand.
col is offline
Tags
'89 camaro
