1969 RS Camaro rear back up lights in-op? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 29th, 09, 04:48 AM Thread Starter
BRANDON
i bought a car from a team member and for some reason my rear back up lights went out? duh? is it a simple fuse or are both bulbs bad?or is it an adjustment in the shifter? they did work fine.i havent checked anything yet, but i will tonite.(looking for idea's)thanks, brandon.
FULLRUT is offline
post #2 of 9 (permalink) Old Dec 29th, 09, 05:32 AM
Send a message via AIM to smith69z
Re: 1969 RS camaro rear back up lights in-op?
Try the adjustment on the sterring column first. Dscinnect and slide the contact until the lights come on or don't come on. Then move on.
69 Fathom Green RS/Z-Endura bumper - Never finished but finally certified.
smith69z is offline
post #3 of 9 (permalink) Old Dec 29th, 09, 05:54 AM
Brandon -
If I remember the car correctly, it is a column shift auto, correct? If so, like Don says the neutral safety and reverse lamp switch is at the base of the column inside the car, on top of the column. Without taking anything apart, you should be able to move the gear selector lever around and see if it triggers the lights at all in any position. If it does turn them on, just not when the selector is in reverse, then it is a simple adjustment issue.
If it doesn't trigger them in any position, the next thing I would do is use a multimeter to check for 12V (with key in and in run position) on the pink wire leading to the NSS/reverse light switch.
If you have 12V showing on the pink, then I'd move to the rear light harness disconnect (rectangular block behind the left taillight, where the middle body harness meets the rear light harness), and check for 12V on the lime green wire (with the key on and selector in reverse).
You can also remove both the pink and green from the reverse lamp switch and use the multimeter to check for continuity at the switch. Hook it up, and if the MM beeps when the selector is in reverse, the switch is good.
I don't have the fuse block diagram here, and I can't recall what else is on that circuit. Try some basic checks, and then we can go from there.
Eric
Eric Kammerer is offline
post #4 of 9 (permalink) Old Dec 29th, 09, 05:57 AM
Looking at a pic of a 69 fuse box, it looks like the reverse lamps are on a fuse with the directionals. Do the turn signals still work?
Eric
post #5 of 9 (permalink) Old Dec 29th, 09, 06:19 AM Thread Starter
BRANDON
Eric, yes its bill old car and it is automatic on the col. And yes the turn signals are working correctly,.. It is an rs car.
FULLRUT is offline
post #6 of 9 (permalink) Old Dec 29th, 09, 06:31 AM
As Eric suggests, Back the car to a door/wall to see the reverse lights or not as you slowly run the gear selector threough the gears.
If they do light, then its an adjustment.
post #7 of 9 (permalink) Old Dec 30th, 09, 05:19 AM
BILL
SPARKY69's Avatar
dont make come up there and fix it for you brandon!! hahahaha... did you get it fixed yet??..take it easy one the ole girl..its not a reher morrison engine under the hood...hahaha
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #8 of 9 (permalink) Old Jan 4th, 10, 10:08 AM Thread Starter
BRANDON
thanks guys, i got them working, it was a adjustment.
FULLRUT is offline
post #9 of 9 (permalink) Old Jan 4th, 10, 10:21 AM
Sometimes it IS the simple things.
Eric
