Engine noise in #7 cylinder - 302 V8 - Team Camaro Tech
post #1 of 22 (permalink) Old Jan 1st, 10, 04:09 PM Thread Starter
68z
I all of a sudden have an engine noise in #7 cylinder. when I pull the plug off # 7 cylinder , it goes away . Its like a "ticking noise" . I am thinking a valve let loose or head gasket?
tr68z is offline
post #2 of 22 (permalink) Old Jan 1st, 10, 06:19 PM
bill
Re: engine noise in #7 cylinder - 302 V8
when you take the plug wire off? i assume that you did that and noise goes away. it is a wristpin knock.
hereitis67 is offline
post #3 of 22 (permalink) Old Jan 1st, 10, 06:42 PM
george
Welcome to the world of a cracked piston skirt before fingering a wrist pin.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 22 (permalink) Old Jan 1st, 10, 08:23 PM
If equipped, header gasket leak at the cylinder head, or cracked manifold?
Only after other suggestions given first.
post #5 of 22 (permalink) Old Jan 1st, 10, 08:37 PM
Steps
I would go for the collasped piston skirt.....
Climb underneath or put the car on a hoist a shirt tends to be laoder from underneath the car.
Steptoe is offline
post #6 of 22 (permalink) Old Jan 2nd, 10, 03:44 AM Thread Starter
68z
how much $$ would I be looking at the get the piston fixed ? would that be rebuilding the motor?
I noticed last night that the header on the 7th cylinder looks like it has lots of corrosion around it. could it be cracked causing a leak?
tr68z is offline
post #7 of 22 (permalink) Old Jan 2nd, 10, 03:46 AM Thread Starter
68z
I noticed there is lots of corrosion around the header @ 7th cylinder. Could header have cracked?
tr68z is offline
post #8 of 22 (permalink) Old Jan 2nd, 10, 04:41 AM
Yes, or rusted.
You can remove the spark plug, squirt some oil into the cylinder, re-install the spark plug, and during engine start-up, view the smoke coming out the crack/hole.
post #9 of 22 (permalink) Old Jan 2nd, 10, 09:55 AM
Charlie
I would try the easy remedy 1st. That being the header leak or crack before I go diving into the motor. I'm not saying anyone is wrong. All I'm saying, you may get lucky and it be a bad gasket or a cracked header and you won't even have to go into the motor. I know when I had a bad header gasket, it sounded like valve tapping.
67CamaroRS/SS is offline
post #10 of 22 (permalink) Old Jan 3rd, 10, 06:16 AM Thread Starter
68z
I looked at it again and it seems like noise is coming from valve cover area and not the lower part of the motor....I put my hand around header area and could not detect any leaks.
valve adjustment possibly??
tr68z is offline
post #11 of 22 (permalink) Old Jan 3rd, 10, 06:21 AM
Andrew
Andrew69's Avatar
It could be something as simple as the plug wire arching to the header. Rule out the simple things before you tear down the engine.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 22 (permalink) Old Jan 3rd, 10, 07:02 AM
Michael Gekko
Start the engine up at night with no lights on and do a visual, if the header is leaking that bad or there is a crack somewhere you might be able to see where it is.
the oil in the cylinder suggestion is good also.
Eleanor's Nemesis is offline
post #13 of 22 (permalink) Old Jan 3rd, 10, 07:59 AM
I looked at it again and it seems like noise is coming from valve cover area and not the lower part of the motor.....valve adjustment possibly??
Very possible. Be sure to have vc/cover gaskets handy first.
Use the ICEO method;
intake closing, adjust the exhaust valve
Exhaust beginning to open, adjust intake
post #14 of 22 (permalink) Old Jan 3rd, 10, 10:38 AM
Steps
Use a long scew driver, one end on different parts of the engine the other pressed to your ear....or better still buy an elcheapo mechanics stethoscope
Steptoe is offline
post #15 of 22 (permalink) Old Jan 3rd, 10, 12:49 PM Thread Starter
68z
what is the ICEO method? Never adjusted valves before, but per the manual it looks easy? Let me know i f I should try this myself or hand over to a PRO.
tr68z is offline
