Th 400 speedo problem - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 1st, 10, 05:09 PM Thread Starter
Speedometer will not calibrate correctly after 50 mph...
Will begin pegging forward after 50...
Replaced cable, checked for correct color/tooth gear (yellow)& checked 15 tooth drive gear (gray/silver)...
Do not know exact year of the th 400 in my 69 chevelle...
Currently running 15 255r tires & 342 gear
any advice or solution appreciated...
terryn69ss is offline
post #2 of 3 (permalink) Old Jan 1st, 10, 06:39 PM
Paul
Re: Th 400 speedo problem
Check out this site....
http://www.tciauto.com/Products/Tech...eedo_gears.asp
I came up with a 36 tooth gear (white) using
255 70 R 15 (28.9 diameter)
15 drive teeth
3.42 gear ratio
Smhigh is offline
post #3 of 3 (permalink) Old Jan 1st, 10, 06:57 PM
If it's pegging after 50 mph, but OK up to 50 mph, the problem is not the gears. There is a magnetically coupled disk arrangement connected to the pointer inside the speedo. Sounds like it's bent such that it begins to rub together above 50 mph.
dnult is offline
