69 RS headlight doors - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 3rd, 10, 10:05 AM Thread Starter
A month ago I started my 69 RS Z28 to run it and excersise everything. The vacumn headlight doors worked perfectly. I started the car yesterday to do the same thing and the headlight doors would not work at all. What should I check as the car was not touched since last month?
skyman51 is offline
post #2 of 7 (permalink) Old Jan 3rd, 10, 10:57 AM
Re: 69 RS headlight doors
Start by using the manual open switch on the vac accumulator to see if they open - if they do it's upstream somewhere.
on edit :
If they don't open - check to make sure you have vacumn to the accumulator next.
69 Pace Car and 69 Hard top
srode is offline
post #3 of 7 (permalink) Old Jan 3rd, 10, 01:14 PM
Fred
Also sky,,,, touch your car! Get in there and dig. Look around. It sure makes our job a lot easier, if we are needed at all. Standing by,,,
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 7 (permalink) Old Jan 3rd, 10, 01:28 PM
Skip
Skeeter55's Avatar
Any luck yet.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 7 (permalink) Old Jan 3rd, 10, 01:28 PM
Jeremiah
I had the exact thing happen to mine.
I ended up swapping the aftermarket vacuum switch/valve for an original I had and they worked perfectly.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #6 of 7 (permalink) Old Jan 3rd, 10, 01:40 PM
Jeremiah
Skeeter... how are you adjusting your doors with the engine compartment wrapped up? Looks like you got them lined up pretty good.
Jeremiah is offline
post #7 of 7 (permalink) Old Jan 3rd, 10, 01:50 PM
Skip
Skeeter55's Avatar
There DSE... I was bouncing from post to post. My bad
