Sensor making me run rich? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 12th, 10, 03:54 PM Thread Starter
I gotta 1991 Camaro RS with a 3.1 V6. At a cold startup, the engine runs like its got a miss. My Autoxray says the car is running rich and I can't diagnose it at all. For some reason, my ECM wants to keep purging the vapor canister ALL the time. Cold or hot and in any driving condition, the ecm never commands the purging to quit. I'm thinking the ecm is getting a signal from a sensor telling the ecm that it needs to turn on the purge solenoid. I don't know what the ecm relies on to turn the solenoid on or off. I have a good idea that it might be the Coolant Temp sensor. My BLM and Integrator are at 100 and I'm getting horrible gas mileage. The integrator can be on 128 at idle then slowly go down to 85 then idles really crappy and all of a sudden the ecm will compensate to knock it up to 128 again only to start dropping below 100. I don't want to throw parts at it hoping to correct it. Any suggesstions? I have had this car for 15 years and wouldn't trade it for nothing.
Ken
ken3983 is offline
post #2 of 3 (permalink) Old Jan 12th, 10, 04:17 PM
Vintage 68's Avatar
Thumbs up Re: Sensor making me run rich?
Like you said - the CTS is probably the culprit
It will maintain the Purge if it doesn't sense the engine is up to temp.
Causes the fuel map to stay rich also.
Test and replace it and see if the issue(s) doesn't go away.
They will not set a code when bad -
I just replaced one a few months ago to fix a stumble problem ... go fiqure.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Jan 12th, 10, 05:48 PM
Steiner
I agree. See what your program says your coolant temp is. It will stay in open loop and run rich if it doesn't get above 150 degrees or so.
'69 Camaro
500hp/538lbft
Steiner is offline
