69 Camaro won't start - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 25th, 10, 12:27 PM Thread Starter
Shane
I have a 69 camaro 327 auto was running fine then died. Replaced coil, plugs, cap, rotor, wires, pick up coil, ingtion mod. I have spark getting fuel have got to to cough a couple times and thats it oh and have power at the distrubtor too.
69 SS clone is offline
post #2 of 15 (permalink) Old Jan 25th, 10, 01:13 PM
Re: 69 camaro won't start
What kind of ignition/distributor, Shane?
Eric
Eric Kammerer is offline
post #3 of 15 (permalink) Old Jan 25th, 10, 01:23 PM Thread Starter
Shane
GM HEI with cap mounted accel super coil
post #4 of 15 (permalink) Old Jan 25th, 10, 04:38 PM
try to pour a little gas in the carb while someone cranks it and see if you can get it to run that way(be carefull).If you can then you know its a fuel problem. Might pull a valve cover and make sure everything looks good when your trying to start it. Also check the plugs after you crank for a minute and that might tell you something
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
post #5 of 15 (permalink) Old Jan 25th, 10, 05:15 PM
Fred
Just died? Like it was shut off or did it stumble, buck, and give up the ghost? It could be the dreaded stripped nylon cam gear. Easy to check. With the dizzy cap off, watch the rotor while someone turns the starter. No rotation or a hesitation of the rotor means major trouble. The valves, push rods and nearly everything that moves is in big trouble. Cross your fingers. No doubt you'll eliminate that possibility first. Hope you don't have one of those old drives. Good luck. Standing by,,,
128.79mph 1.428 60'
Fred Ficarra is offline
post #6 of 15 (permalink) Old Jan 25th, 10, 06:21 PM Thread Starter
Shane
It just died. it has a geardrive in it and everything is good to go with that removed valve cover and everything is working like it should.
post #7 of 15 (permalink) Old Jan 25th, 10, 06:32 PM
Skip
Skeeter55's Avatar
Ignition switch on the steering column, also check the harness at the column to make sure all pins are making good contact.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #8 of 15 (permalink) Old Jan 25th, 10, 07:11 PM
JAY
You do have power to your dist thru the hot wire..Right? this has to be some thing really different...you've changed every thing, might try a compression test on couple cylinders. could have jumped time. Is there spark at plug wires? Sorry just trying to think it thru. get out ole test light and start tracing powers and grounds GOOD LUCK j
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #9 of 15 (permalink) Old Jan 26th, 10, 07:15 AM Thread Starter
Shane
what do you mean ignition switch? Not really following.
post #10 of 15 (permalink) Old Jan 26th, 10, 07:16 AM Thread Starter
Shane
yeah got spark timing seams to be a TDC
post #11 of 15 (permalink) Old Jan 26th, 10, 12:34 PM Thread Starter
Shane
Re: 69 Camaro won't start
after evevrything finely got to running had to switch carbs' stunk a float and it was flooding the motor out as soon as we tryed starting it. Thanks for all the advice!
post #12 of 15 (permalink) Old Jan 26th, 10, 12:41 PM
BILL
SPARKY69's Avatar
congrats!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #13 of 15 (permalink) Old Jan 26th, 10, 06:00 PM
Originally Posted by 69 SS clone View Post
...had to switch carbs' stunk a float and it was flooding the motor...
Stinky floats will do it every time. Glad you got it running again.
dnult is offline
post #14 of 15 (permalink) Old Jan 26th, 10, 06:10 PM
Vintage 68's Avatar
Wink Re: 69 Camaro won't start
Originally Posted by dnult View Post
Stinky floats will do it every time. ...
And all this time I thought the problem was smelly gas
I'm going back over to Tag Team
1968 Convertible
Some trucks
Vintage 68 is offline
post #15 of 15 (permalink) Old Jan 27th, 10, 11:34 AM
Fred
Don't ya just love happy endings?
128.79mph 1.428 60'
