Big block guide plate question? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 25th, 10, 04:49 PM Thread Starter
I have been trying to track down an annoying ticking noise on the left side of my 396 big block. I am fairly certain its a valve train noise. I've adjusted the valves several times and checked just about everything I can think of. I did notice one of the pushrods had some deep wear marks on the side where one of the guide plates was rubbing on it. I bent the guide plate over a little so it wasn't binding with the pushrod. This quieted down some of the noise, but not all of it. My 396 has the stock GM guide plates which I believe were made to fit 7/16" diameter pushrods. The pushrods I have now are Comp Cams 3/8" diameter. I am running a Comp cams roller cam and rockers and these are the required shorter pushrods. Being the pushrods are smaller in diameter the rockers can move side to side more. Is it possible that this could be causing the ticking noise?
refspd is offline
post #2 of 4 (permalink) Old Jan 25th, 10, 05:05 PM
Fred
Re: Big block guide plate question?
What's the cadence? Every rotation? Half engine speed? Do you have a stethoscope?
This reminds me of a story.
Us kids used to hang out at the local gas station. The older guys who had a drivers license and a car would drop by. Us kids hung on every word spoken. Then Fonzie was having a problem with his 32 coupe. It was ticking and no one could figure it out. We were all hanging over the engine. I said "broken fuel pump return spring". Hey, it must have one, right? The looks from the older guys were memorable. Fonzie pulled the pump on the spot. Sure enough. That's when I knew for sure that I was a gearhead.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 4 (permalink) Old Jan 25th, 10, 05:20 PM Thread Starter
Yea I have a stethoscope and i narrowed it down to the drivers side valve cover. Trying to rule out the guide plates. Next I'm gonna pull the intake and look at the lifters. They feel good though "not spongey" . Thanks for the fuel pump suggestion though. Already checked it. Checked valve cover clearance, ran the valves eoic and with it running, checked for exhaust leaks to. Anybody not about the guide plates?
refspd is offline
post #4 of 4 (permalink) Old Feb 13th, 10, 09:31 AM
Ron
Providing you're running a FT cam, with the valve covers off and engine idling ensure all push rods are spinning. Any not spinning is a sign of something wrong - possible wiped lobe or bad lifter. A worn Rocker Fulcrum or Rocker Nut can back off fast and cause that clack or tick. Sometimes the threads on the Rocker Stud are shot or the Rocker is galling the stud. Also inspect for broken Springs and Dampers. By the way, if you're running 3/8" push rods you should be using 3/8" guide plates. It's not uncommon the cut the Guide Plates in two and massage the forks to align the Rocker Tips squarely on the Valve Stems with minimal sweep. The Guide Plate Forks should fit snug but allow the Push Rods to spin. If you see galling on the Push Rods the Guide Plates are either too wide or misaligned. This may not account for your TIC but can cause wear to the Lobes, Rockers and Valve Stems.
After adjusting tappets and a tic is there, with the engine idling, I will use a hardwood stick and push down onto the Rocker Ends to determine where the sound is coming from. When you find the trouble spot you will notice a difference in sound.
I cut the top of an old valve cover to prevent Oil Splash when inspecting the valve train or adjusting Tappets with Hydraulic Lifters:
X2 on that Exhaust Manifold or Header leak ;o)
This was my 70 1/2 Z28
Z15CAM is offline
