slow to open /68 RS headlight doors - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 16th, 10, 05:23 PM Thread Starter
SCOTT
Was wondering, my doors open very slowly (two to three mins.), but they close just fine. Is there a chance I may have the hoses on the canisters reversed. I have replaced the valve on the vaccum tank twice, seems to work good for a while, then gets slow to open again.
Thankyou
OL SCHOOL is offline
post #2 of 3 (permalink) Old Feb 16th, 10, 08:37 PM
Dale
Re: slow to open /68 RS headlight doors
If the hoses were reversed the operation of the doors will be reversed.
How much vacuum do you have at the vaccum valve?
Are they slow when the vacuum valve is worked manually (not using the light switch?
Most likely some of the vacuum is bleeding past the canister seal (vacuum motor) to the closed side of the canister.
Try opening them with the lower hose removed from the vacuum valve, does it work better, if so, one or both of the canisters is leaking internally.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #3 of 3 (permalink) Old Feb 17th, 10, 05:03 AM Thread Starter
SCOTT
Are new canisters prone to leak? mine have only been used half a dozen times. I put them on new within the past year.
