Motor run on - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 23rd, 10, 05:54 PM Thread Starter
sam g.
Motor run on
just finishd my friends 68 camaro and when i go to turn it off the motor doesnt turn off keeps going when the key is off,anyone had the same problem.has external volt.reg.cant seem to find whats the problem
sic7camaro is offline
post #2 of 7 (permalink) Old Feb 23rd, 10, 06:12 PM
Eric
Re: motor run off
Do you have a MSD 6A or 6AL. If so, you will have to run a resistor on your relay that is mounted on your radiator support on the driver side. I had the same problem on my 69, after I installed the resistor was installed the problem went away. Call MSD they will help you through it.
Hope this helps.
Eric
KillerFast is offline
post #3 of 7 (permalink) Old Feb 23rd, 10, 07:16 PM Thread Starter
sam g.
Re: motor run off
no msd it has mallory ignition coil
post #4 of 7 (permalink) Old Feb 23rd, 10, 09:45 PM
Eric
Re: motor run off
It still might be the same thing. Did you change something in the ignition.
post #5 of 7 (permalink) Old Feb 24th, 10, 03:26 AM
Re: motor run off
Next time it's running, remove the yellow wire on the coil, if OE wiring.
If it dies, swap yellow wire at starter solenoid to the other small post.
The above is suggested if nothing was changed elsewhere in the harness and just the coil swapped out.
post #6 of 7 (permalink) Old Feb 24th, 10, 03:42 AM
BILL
SPARKY69's Avatar
Re: motor run off
check your timing also!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #7 of 7 (permalink) Old Feb 24th, 10, 05:19 AM
ZZ_430's Avatar
Re: Motor run on
You didn't mention how long it will run on, but if it just "diesels" turn down the base idle to close the throttle blades more.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
