Road Crud inquiry - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 24th, 10, 06:47 PM Thread Starter
Doug
Road Crud inquiry
...while driving down the road the other day I picked-up a large piece of light weight plastic (kind that cleaner clothes comes in). As expected I could not avoid it and rolled over it, to which I discovered (as expected) it immediately became welded to my exhaust system underneath, around the cat-converter.
The smell is discusting, but other than the smell, (which I hope will eventually go away), I want to know for sure that it will not cause any mechanical problems I may not be aware of?
Appreciate hearing from any Tech guru about my concerns!!
Thanks,
Tblazer
tblazer is offline
post #2 of 5 (permalink) Old Feb 24th, 10, 06:52 PM Thread Starter
Doug
Re: Road Crud inquiry
Sorry, I forgot to describe my car: '99 Camaro SS
tblazer is offline
post #3 of 5 (permalink) Old Feb 24th, 10, 07:50 PM
once it burns off the exhaust, you will never know it was there.. well, some of it might have gotten wound up around the driveshaft or behind the yoke on the rear end- it might be worth the time to crawl under there and check to make sure it isn't wrapped around the yoke before it can eat thru the seal.
you don't plan sincerity.
novaderrik is offline
post #4 of 5 (permalink) Old Feb 25th, 10, 07:03 AM
Jeff
same thing happened to my 68.
jeff_gates is offline
post #5 of 5 (permalink) Old Mar 4th, 10, 08:59 AM
Hmmm, the guy that painted my car also had a lot of paint on the exhaust. It stinks but nothing bad can happen unless it gets hot enough to flame.
deerhunter is offline
