Shifting Into Park - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 28th, 10, 04:36 PM Thread Starter
Mantas Galijota
Shifting Into Park
So this has been totally ravaging my brain maybe someone can help me out. It seems that my shifter won't go into park heres the symptoms im having ill push the lever all the way into park position but when i let go of the break the car acts as if it's in reverse and starts driving backwards if I press the gas pedal it accelerates when i shift down one same thing but the reverse lights come on the thing is it lets me take out my key when its in park but the car slighlty rolls basically i have 2 reverse gears no park and no 1st gear car drives fine everything seems in order the only other thing is when i start it the rpms jump and the vechicle right away goes in reverse any help
trippym is offline
post #2 of 6 (permalink) Old Feb 28th, 10, 05:15 PM
Re: Shifting Into Park
What type of shifter,Stock or aftermarket???? Sounds like a cable adjustment issue.
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 6 (permalink) Old Feb 28th, 10, 05:22 PM
Ray
More than likely shift cable or linkage needs adjusted.Chock wheels and set ebrake and take off at tranny,move shift lever by hand and see if you have all detent postions.If good install cable or linkage put in park and see if you can move lever on tranny by hand into park.If yes then adjust your cable or linkage.
totalcomfort is offline
post #4 of 6 (permalink) Old Feb 28th, 10, 07:47 PM
Jay
What kind of car?
Juicer2 is offline
post #5 of 6 (permalink) Old Mar 1st, 10, 05:32 AM Thread Starter
Mantas Galijota
95 camaro everything stock automatic 3.4 this happened right after i hit a pothole can anyone guide me through adjusting the linkage
trippym is offline
post #6 of 6 (permalink) Old Mar 1st, 10, 08:01 PM Thread Starter
Mantas Galijota
Thanks for all your help found the problem a loose bolt holding the lever that the cable snaps on to one socket a little tightening and seems to be right
trippym is offline
