87 Iroc Z 28 refuses to pass CA Smog (Hi NO) - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 2nd, 10, 08:06 PM Thread Starter
Question 87 Iroc Z 28 refuses to pass CA Smog (Hi NO)
would love help! 87 iroq w/305 engine. Replaced EGR valve, EGR solenoid, knock sensor, wires, plugs, rotor cap, spark ignitor, TPS (throttle positioning sensor), TSU (temp sending unit). Second smog test gives Fail for NO of 916 ppm (max 772) @15 mph but passes with 628ppm at 25mph. Have run 2 cans seafoam through. Stumped! Any thoughts?
BudgetRacing is offline
post #2 of 11 (permalink) Old Mar 2nd, 10, 08:18 PM
Dale
Re: 87 Iroc Z 28 refuses to pass CA Smog (Hi NO)
Does the egr valve work, is it the correct one? Could the EGR intake ports be restricted.
MAF's were a real problem child with the TPI, is it working correctly? They tend to report lower airflow than what is correct, and leaning the AF ratio.
Is the ignition timing set correctly?
Is the cat working?
What thermostat is in the car? Cooling fans working correctly/
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #3 of 11 (permalink) Old Mar 2nd, 10, 08:29 PM
Steiner
The majority of NOx is eliminated by the catalytic converter. If yours is original, 23 years is a lot of time on it.....
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 11 (permalink) Old Mar 2nd, 10, 09:02 PM Thread Starter
Thank you both. I've been avoiding the CAT because for some reason the exhaust is welded on. I have 4-barrel carb on this and EGR valve was replaced. Will post back once we attack the CAT.
post #5 of 11 (permalink) Old Mar 3rd, 10, 12:08 AM
Levi
Replace that cat and I guarantee you that it will pass smog.
1975 Camaro "Black Out"
.Bad75. is offline
post #6 of 11 (permalink) Old Mar 7th, 10, 04:03 PM
Fred
Or,,,,,,, put a bigger cam in it.
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 11 (permalink) Old Mar 7th, 10, 04:41 PM
Art
May also be running a little hot, if you can get the coolant temp down a little it will drop the NOx levels. I've gotten a few to sneak through with a cooler t-stat. Cooler combustion chamber temps lower NOx, running the coolant temp a little lower helps this.
Artie
67 Camaro
99 T/A Daily Driver
Previous:
67 Camaro Traded for my 98
68 Camaro Street/Strip
98 Camaro Race car Best ET 9.08 @ 152 1.18 60'
Dyno sheets don't win races, see you at the track
SRGN is offline
post #8 of 11 (permalink) Old Oct 31st, 10, 07:53 AM
Jeff
EGR solenoid location?
Hey guys, on the 305 TPI where is the EGR solenoid located? My friends smog shop told us it is bad and needs replacement, but we don't know for sure where the thing is.
-shoe
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
shoe is offline
post #9 of 11 (permalink) Old Oct 31st, 10, 08:10 AM
EGR is under the plenum, center of intake.
john68 is offline
post #10 of 11 (permalink) Old Nov 2nd, 10, 06:05 PM
Talking Re: 87 Iroc Z 28 refuses to pass CA Smog (Hi NO)
Ah yes. I remember my first time pulling the plenum off a TPI motor. The good news is after you take it off and put it back on a half dozen times, you get pretty good at it.
dnult is offline
post #11 of 11 (permalink) Old Nov 8th, 10, 09:02 AM
Ryan
Oxides of Nitrogen tend to form at higher than normal comustion temps...replacing the t-stat would likely help that as mentioned above...but a good old fashioned carb rebuild could help if you are getting a lean condition at the 15mph test.
I would guess if the car is smooth and driveable as is...a new Cat would likely get you there.
1969 X66
1964 Corvette 327/300
1998 SS Vert
1987 Regal
hatdragracer is offline
Tags
1987, emissions, iroc z28, nitrous oxide, smog
