HOLLEY help - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 6th, 10, 06:56 AM Thread Starter
jeff
1SLOW64's Avatar
Question HOLLEY help
holley 950cfm 4150 on a 406sbc question.
Idle is fluctuating about 200-300 rpm's at idle and the seems to be a flat spot just off idle when i step on the gas.
Info on engine: Distributor is locked out. solid roller cam. holley blue pump 6psi @ carb. Also hear a whistle sound at full throttle.
Thanks jeff
1969 X66 PROJECT:
2002 C5 COUPE ELECTRON BLUE SOLD
1987 BUICK GRAND NATIONAL SOLD
1964 CHEVY II 406 SOLD
1SLOW64 is offline
post #2 of 4 (permalink) Old Mar 6th, 10, 07:29 AM
Harry
dawg's Avatar
Re: HOLLEY help
holley base gasket is leaking = vacum leak
off idle stumble is caused by play in accelerator pump ( adjust so there is no play and any slight movement of the throttle will cause fuel to squirt out of shooters.
I had same issue last year and after adjusting this fixed it.
I also opted for the bigger REO accelerator pump kit .
434 stroker
US Navy retired
dawg is offline
post #3 of 4 (permalink) Old Mar 8th, 10, 09:30 AM
Harry
dawg's Avatar
Re: HOLLEY help
Gee once again I spend the time to help out a fellow member and one would think he would reply?
434 stroker
US Navy retired
dawg is offline
post #4 of 4 (permalink) Old Mar 14th, 10, 03:19 PM Thread Starter
jeff
1SLOW64's Avatar
Re: HOLLEY help
Sorry I didn't reply back in a timely manner. I was kinda busy. You know, with a thing called LIFE.
Anyways. Update on carb issue: Had some garbage in one of the idle mixture circuits. That fixed the surging problem. Readjusted acc. pumps.
Took car to track. Ran like a champ. Made a good pass then lined up for 2nd pass, released trans brake and POW!! bent drive shaft and sheared u-joint bolts off at pinion yoke.
Time for an aliminum shaft with 1350 joints
1969 X66 PROJECT:
1SLOW64 is offline
