Power Steering works only at higher RPM - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 8th, 10, 01:34 PM Thread Starter
Same deal everything is brand new. My P/S only turns easy after the RPM gets up to 1000 or more. So at a idle like trying to park the car you have to muscle the steering wheel to get the car to turn. But driving the car down the street you can steer it with 1 finger. Thanks Team Camaro
copol72 is offline
post #2 of 5 (permalink) Old Mar 9th, 10, 06:40 AM
Re: Power Steering works only at higher RPM
You say that everything is new so we should be able to dismiss that fact that your pump is old and tired and just isn't putting out flow like it used to.
There are different models of Saginaw pumps. They all look the same on the outside but different rings, rotors, and vanes inside the pump dictate how much fluid is displaced with every revolution of the pump driveshaft. It is possible that you just have a low displacement Saginaw pump that is just not putting out sufficient flow at low engine rpms that you experience at parking speeds. I would suggest checking with your source where you purchased the pump to see if they have any specs.
Also, the size of the power steering pump pulley versus the size of the crankshaft pulley can have a direct affect upon how much fluid is being pumped through the circuit. I have seen "power saving" pulleys that cause the pump to spin too slowly at parking situations.
JIML82 is offline
post #3 of 5 (permalink) Old Mar 25th, 10, 06:16 AM
Loose or slipping belt..................
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 5 (permalink) Old Mar 25th, 10, 07:36 AM
Put the front end up on jacks, and try the steering without power. Could be something binding in the steering assembly?
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #5 of 5 (permalink) Old Apr 4th, 10, 05:12 AM
PA Camaro Guy's Avatar
I would check your pulleys too. Underdrive pulleys do things like this, and can also make for low voltage conditions at idle too.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
